Which tire is better?
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
I have a choice between BFG Comp T/A or G-Force KD tires. Which one is the better tire to go with?
Car: 1986 IROC-Z
Engine: peanut cam LB9
The g-force T/A is a newer tire and I believe it was brought out to eventually replace the Comp T/A. I just bought a set of G-force T/A KDW's for my ROC. Although I won't get them on for about a week.
Jason Lodder; 86 IROC-Z, 305 TPI/700R4, Flowmaster Exhaust, Hypertech Thermomaster Chip, K&Ns w/baffles removed, Throttle body airfoil.
"The reason most import drivers only focus on looking fast is so they can sit there staring at their car and dream about it being fast, because there's no way for them to match American muscle."
I've also heard the same thing; i loved the comp version haven't had a chance to run the replacements. I went with michelin because it's a little harder compound, the comp ta's and the like are so soft they wear out easy if you play around at all.
overall though they are nice tires for sure.
Get the G-Force instead of the Comp TA's. I recently saw an LS1 pull a low 1.8 60 ft. on a set of G-Forces - on his way to a 12.5 pass. He had a 4000 stall, and was still able to pull low 1.8's. But, if you want a tire w/ longer life and don't care about traction - get a harder compound tire.
1986 IROC, fully loaded, Mini Ram'd 383, Art Carr 700R4, Accel DFI, 12 bolt rear, etc, etc......
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
