Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
I need some help
Old Nov 23, 2001 | 11:14 AM
GTA Guy's Avatar
I need some help
Hey, my car has been leaking anti freeze into my heads so I am going to have to get that fixed. I figured since I would be getting it done I should throw some new heads in. What would be good to put into my 89 GTA Trans Am 350. One more thing is there anything else I should get done while its apart?
thanks guys
1989 GTA Trans Am
350 5.7
Hypertech Stage 2Chip
Low Temp Thermostat
Old Nov 23, 2001 | 11:52 AM
killer305's Avatar
i would put on some new heads, antifreeze really eats up your bearinggs
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, MSD probillet Distributer/ coil, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension.
Old Nov 27, 2001 | 05:55 PM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
depends how much you want to spend, if you didnt want to spend alot or if you did, personally i would get the afr heads...but they cost a pretty penny and id have them cnc ported and polished...
-mark
86 iroc
-comp cam .444 lift with manley valve springs
-comp magnum 1.5 rockers
-tpis adj. fuel pressure regulator
-tpis airfoil
-homemade ram air with modified maf
-k and n
-3 inch random cat, 3 inch intermediate pipe and flowmaster muffler
-msd cap adapt with blaster gm coil, msd 6al and accel 8.8 wires
-ads strip chip
-console megashifter
-phantom gauges
-stereo system
-91 rs ground effects...soon
Old Nov 29, 2001 | 12:58 PM
VampireHunterC's Avatar
Well, if you have the green, while you have the engine apart, why not go that xtra step and do a rebuild?
Old Nov 29, 2001 | 01:16 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
If the bottom end is still solid, I would get some vortec heads and the scoggin-dickey vortec TPI base. Even with the stock cam on a 350, you should see 50hp +
Just my $.02
