Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Tuning a AFPR
Old Nov 14, 2000 | 11:50 PM
BenDoe's Avatar
Tuning a AFPR
I just ordered an Ajustable fuel pressure regulator and am plannin on putting it on my car this weekend. I have a hi-rev cam, headers, dual cats, flowmaster, and have enlarged valves with a stock computer... how do I go about ajusting it perfectly?
1991 Z28 305 1LE, TES headers, 3 Chamber flowmaster, Hi-reving cam... the usual street racer
Old Nov 15, 2000 | 01:20 PM
theformula's Avatar
Which one did you order? hopefully the one that adjusts with the 8mm.
Anyway, a little advice. Go to parts america or advanced auto and replace the spring and orange gasket type thing. They usually go when you bump up fuel pressure. Mine did, and believe me I wasnt too happy about taking my plenum off. You can tell when they go because the FP will remain the same with hose on or off. Anyway it is listed under MPFI there. Called the Fuel pressure regulator kit. Its only $29 compared to GMs price of $95.
Now as for optimal fuel pressure setting, you really have to play around. I recommend an electrical/digital FP gauge inside the car. That way you can constantly monitor the fuel pressure.
I have tried FP settings from stock (42psi), all the way to 59psi. I have found the best setting for my setup to be anywhere from 35-39 (vacuum hose on). You'll know you're too rich when black comes out of your pipes.
Oh yea, when you set the fuel pressure, do it with the car idling. EX(If your at idle, and the FP is reading 35. Disconnect the vacuum hose and it should rise to around 42. Vacuum hose disconnected usually makes the FP rise about 7#s.)Next, disconnect the hose. With the vacuum hose disconnected it simulates wide open throttle. When you have it to your desired setting put the hose back on. Now make a full throttle run and see if it reaches your setting.
To adjust the FP on mine, I usually have to take the plenum extension off, and I disconnect a spark plug wire. Thats the only way I can fit the wrench in there. Just make sure you put the wire back on!
Thats about it, I tried to answer all questions you may have in the future too! phew
Good luck.
'92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (42psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges...ZZ9 cam (i still have to install it )
[This message has been edited by theformula (edited November 15, 2000).]
Old Nov 15, 2000 | 01:27 PM
theformula's Avatar
Do yourself a favor and get a custom chip bro. Especially with an aftermarket cam in a speed density. Try www.fastchips.com
'92 Formula
305 TPI 5speed
1LE package
Old Nov 18, 2000 | 08:26 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
if you get the one from crane cams make sure you get a shorter adjustment screw than the one they give you, it hits the plenum!
i got about 1/4" shorter works nicely.
88 CAMARO RS
87 IROC-Z DRIVETRAIN
305 TPI, 700R4, 3.73s
ported plenum, performance resource chip,edelbrock TES Headers and cat-back, K&Ns, AFPR, rest is stock.
15.0 @ 92.5 (bald tires)
Old Nov 19, 2000 | 10:45 AM
theformula's Avatar
I use the Crane and I have no clearance problems really. I just take off the plenum extension and one spark plug wire and an 8mm wrench fits in there nicely.
I guess it would be easier with a smaller bolt though.
'92 Formula
305 TPI 5speed
1LE package
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
