Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
S&W Adjustable Torque Arm
Old Jan 10, 2007 | 12:54 PM
kaylin4u's Avatar
I was wondering if anybody owned this tq arm? I have a Borg Warner 9 Bolt, and hope I don't run into problems with installation and ride.
Old Jan 10, 2007 | 06:01 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
nope not me, but I have a few other things from them and everything I have ordered has fit extremely well and has shipped out quick, keep us posted
Old Jan 10, 2007 | 06:07 PM
kaylin4u's Avatar
I'll be making a purchase at the end of the month. I'll try and be back with pics and an update.
Old Jan 13, 2007 | 03:45 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Let us know how things work out and if you are happy with the results. Might consider them if everything is positive.
Old Jan 14, 2007 | 10:51 PM
kaylin4u's Avatar
We'll do.
Old Jan 16, 2007 | 01:13 AM
Profootbrake's Avatar
Car: 92 camaro Z28
I have had one for about 5 years now and it works great on the strip and street
Old Jan 18, 2007 | 11:26 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Does it mount to the trans or to the trans tunnel? Is it adjustable? I wasn't aware they even made one.
Old Jan 19, 2007 | 09:35 AM
kaylin4u's Avatar
Well, it doesn't mount to the tranny housing. You have to order their cross member and weld it up to the frame. I was going to get Subframe connectors, but since theirs mounts to the rockers as well, I went ahead and purchased the entire kit which includes everything to mount it to your car. They were great to deal with. I can't wait to get it in.
Old Feb 4, 2007 | 06:18 PM
kaylin4u's Avatar
We just finished the install. I love the setup, but there is a ground clearance issue with the cross member. The drive shaft loop sits down about 1.5 inches lower than the cross member, so it drag terribly. We couldn't get the car off the alignment rack without it hanging, so we jacked up the front end, then rolled it off. My plan is to either take off the drive shaft loop, or grind off the lip on the bottom of the cross member, and relocate the drive shaft loop.
Otherwise, the kit was easy to install. We welded everything instead of bolting it up, because there was some questions about the drivers side rocker as I have some rust there. I've got some pics with my cell phone, but you really can't tell alot about the install. I'll try to get it back on a lift and get some pics using my digital camera.
But as far as S&W Racing, they've done their homework. As I said, I'm very well pleased in the quality. The ground clearance of the crossmember & drive shaft loop, is my only nag. Keep in mind, I've never ordered and installed SFC's before, so this might not be the first complaint for SFC's.
Old Feb 5, 2007 | 02:28 PM
Car: 92 camaro Z28
Ground clearance is the only problem that I have had with my too
Mine is mounted to a custom cross member that is on the 12 year old subframe connectors
here is a link to s&w www.swracecars.com/pdf/catpg17.pdf
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
