Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Update on Dual Gate Two For Camaro/Firebird
Old Nov 6, 2000 | 02:43 PM
Tad's Avatar
Tad
It's now available! I just order one from summit and said they had five in stock. I will let you know more when I get it (wedsday or thursday).
Old Nov 6, 2000 | 04:13 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
man i ordered that thing last june and it was on back order and i finally cancelled the order thanksgiving of last year. turns out i didnt need a new shifter...just needed to tighten cable. i want pics.
Rick
90 Camaro RS 305 TBI
400 on the way!!
Old Nov 6, 2000 | 06:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
While you're waiting, you might want to pick up an extra console top at a wrecker just in case. You'll have to saw the ashtray off for the Dual/Gate.
1984 Silver Z28, 383 cid 4 bolt, ARP Fasteners, 2 1/2" Cowl Induction Hood, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Magnum Roller Tip Rockers, MSD6AL Ignition, Blaster2 Coil, Recurved HEI Distributor, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flo-Pro Twister Muffler, 4 Wheel Disc Brakes, Oil Cooler
Old Nov 8, 2000 | 03:35 PM
Tad's Avatar
Tad
Well it's here. will install tonight or tomorrow. but won't know how it really works for a while yet no engine or trans in car right now.
Old Nov 8, 2000 | 04:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Any comments on the general quality of construction or anything else?
Old Nov 8, 2000 | 11:00 PM
Tad's Avatar
Tad
Very good constrution. It also uses the factory shift cable, the parking lock cable, the factory netural safty switch. so there is no cutting of wires you just remove the switch from your old shifter and mount it to the hurst shifter and plug it back in.
Old Nov 9, 2000 | 03:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The factory shift cable?? Can you replace it with a new aftermarket one, or are you just limited to a new factory cable?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 17, 2000 | 04:25 AM
Irockin's Avatar
My Brother in-law and I installed one in his 87' Iroc last weekend. It took about 45 minutes and it looks great. We just went to Year one/next gen and they had it in stock for $229. Oh yea, it works as well as it looks.
Old Nov 17, 2000 | 10:05 AM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
Hey Irockin or anyone with experience, I have a couple of questions on the actual use of the dual gate 2. Is the performance side of it like a ratchet shifter? Like if you slam it from 1st to second, will it catch and not let you overshift it to third? And also if you're in third gear, and slam it back into second, will the tranny go to second or will it wait till you decrease speed to do that? Same thing opposite way, if i go from second to fourth for gas mileage, will it go into fourth, or wait till it naturally goes through third and then fourth? Thanks, your help is much appreciated.
Old Nov 17, 2000 | 12:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I believe there's a stepped gate, so you have to move the shifter slightly to the side before moving it forward or back into the next gear.
Old Nov 19, 2000 | 06:54 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Had mine about a year now... The 2nd Gate could be a little more decisive, apart from that I love it..
'86 Iroc ZZ4
Best Run 13.8 @ 100mph
I told you to blow the bloody doors off!
The British Firebird/Camaro Site
Old Nov 19, 2000 | 11:12 PM
noam's Avatar
is it possible to fit a t-handle on that shifter, i like the look of a t-handle much better than the ball, other than that i love that shifter.
Old Nov 21, 2000 | 11:49 AM
bzznczzn's Avatar
Anyone using a B&M Mega shifter? I have one in my 65 Malibu and love it.
Old Nov 22, 2000 | 02:36 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Hey noam, yep the 'ball' just unscrews, was thinking of getting something a little funkier on there myself, though the ball does ring back memories of the original Muscle Car
Old Nov 22, 2000 | 08:20 AM
noam's Avatar
ah sweet zz, one more question, how does it shfit ie: where is the button for it? (is there a button you have to press for it???) i don't see one in the pics...i know the megashifter and hurst v-matic2 have the little pull thingie, which is pretty sweet imho, but if this thing is better than the v-matic 2 (i've heard nothing but horror from the megashifter so screw that) i'll probably get this one.
Old Nov 22, 2000 | 08:49 AM
IROCYOWORLD's Avatar
Old Nov 22, 2000 | 08:56 AM
Hey Markolc
I,m Irockin's brother-in-law.. The dual-gate shifter is great. But you can overshift, Yes there are notches to catch gears, but overshift is still possible. I found that if you just bump it in gear it dosen't overshift, I've only had it for a couple of weeks and it gets easier to control my shifting the more i use it. If you slam it back to 2nd it will go back to 2nd right away, so be careful with that. Yes you can skip gears but your tranny will go through the complete shift sequenc anyway. Hope this helps you.
Old Nov 22, 2000 | 08:58 AM
Brian K's Avatar
Here is one too.. I got it back in 95.
http://geocities.com/overlift/Dcp02083.jpg
-KMAK
Old Nov 22, 2000 | 09:04 AM
Hey noam,
The push button is totaly elimanated when you go to the dual-gate shifter. Once you pull the frame for you original shifter you'll see where that push button comes into play. I'ts not part of the tranny, just a part of the type shifter you're using..
Old Nov 22, 2000 | 08:32 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
So since there's no button or anything, I can accidentally shift into 1st or reverse at high speeds if I move my hand suddenly? Is there any lockout or anything to prevent that? Once I get into a position, I want it to stay there (unless I'm in the 2nd gate).
Old Nov 23, 2000 | 02:24 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Ok, to answer a couple more questions, Noam there is no button, if you want to 'play' you only use the 2nd Gate... Ironically it does 2 things;
1) It eliminates accidentally hitting Reverse gear, and I found if you put pressure to the shifter (to the right) it will spring up a gear at a time... but it can be tricky not to overshift. Get it right though and try to remove the grin it puts on your face.
2) Psycologically you feel like you are in a race situation, its like lifting that little red flap over the missile switch on an F-16 type feeling.. Even now I only ever use the 2nd Gate when going to the strip or the occassional Traffic light Grand Prix But like a stash of dirty magazines, you know its there
'86 Iroc ZZ4
Old Nov 23, 2000 | 02:43 PM
91FastBird60kmiles's Avatar
Hey, that looks awesome!
Will it work in a firebird?
if anyone has pics of it in a firebird please post them or email them to me at fbm_frame_rider@yahoo.com
And can someone please explain it to me a little better, i must be dumb!
thanks guys
Old Nov 25, 2000 | 02:15 PM
Sith Lord's Avatar
I had a 79 Hurst/Olds and it was orginally equipped with the dual gate, and I can't wait to get one in my 87 IROC, now I have to find carbon fiber to make an overlay that matches the rest of the interior.
70 RS (for sale)
81 Z-28
87 IROC-Z 350 no T-tops
"Rock & roll doesn't create psychos it just helps psychos be more creative"
Old Nov 26, 2000 | 09:08 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Hey Sith, I've got carbon Fibre overlays in mine, check them out at my site, in my sig.. Looks good I think
'86 Iroc ZZ4
Old Nov 26, 2000 | 10:30 AM
Sith Lord's Avatar
Hey ZZ4 looks good where did you get the carbon at to do the dual gate?
70 RS (for sale)
81 Z-28
87 IROC-Z 350 T-tops
Old Dec 6, 2000 | 12:30 AM
danzig27's Avatar
Car: 91 Camaro Z28
Transmission: TKO 600
Axle/Gears: 10 bolt 3.23
Maybe I missed it somewhere earlier..but could someone explain to me how this thing works please?
Wally
86 IROC with the "unknown motor"
84 Berlinetta
Old Dec 6, 2000 | 03:11 AM
Novaguy76's Avatar
It is realy simple to operate. There are 2 sides to the shifter (as you can see in teh pic.'s). The side closest to you is for normal operation. you can go from park to 1st and from 1st to park. Now in a "race" situation you would put the shifter in neutral (I beleive.. it may be drive) and move the shifter handel to the right to put it into the second side. Now the second side works just like a 74 - 81 factory ratchet shifter. you can move it from drive to 1st with no problem and from 1st to drive with no problem the way you get it stop at each gear is by puching the handle to the right as you up shift. There is a little catch that sticks out of the shifter handle down inside there and it catches on these peices that stick out of the gate. So basicaly when you go from 1st to 2nd you push the handle up and to the right (at an angle) and it will stop and not go any farther, then let it spring back over and do the same thing again for 2nd to 3rd and so on. It may sound a little confusing at first but it is realy easy. If you want to see how it works before you lay the money down for one go find any late 70's Camaro or Firebird that has the factory shifter still it the moves from side to side (there are 2 different kinds one that "wiggles" will move about an inch from side to side and one that is "solid" will not move side to side at all) The one that moves side to side works the same way. We call them the "stealth shifters" they are great for factory appearing "sleeprs" hot rods...lol
ZEEYAA
Apr 16, 2023 08:29 PM
zman1969
Oct 1, 2015 11:09 AM
