does anybody run the new gtech pro ss performance meter, and pics esp. at night
also, can you mount it on your dash, like beside of the a/c vents, or will that cause it to not read correctly?
I use the older version when tuning my truck......its pretty accurate once you get the initial setup dialed in. You can mount it anywhere as long as it dosent move or fall off from where you have it mounted. A great tool for tuning when a dyno or the track isnt an option.
Another brand says that you can't angle it to the driver, would angling it throw off all of the readings or just the g force?
still would like pics thanks
that meter is just great, ihaveit andlove it
