Suspension Techniques
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Has anyone tried their sway bars? I have been researching who had the largest diameter solid sway bar and it seems like they have it (1 3/8").
Was just wondering if it is made of quality steel because the price seems so much lower compared to smaller diameter bars from differant companies.
Note: I want a super stiff sway bar for autocrossing.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: Suspension Techniques
it worked pretty good for me.. too bad i'm tryin to sell it.. i dont need a big front sway bar for a drag racer..
let alone any sway bar.. if you werent soo far i would sell it to you.. you could probably get a new one for less than if i were to ship it..
with a set of eibach sportlines and junk monroe sensatrac struts and shocks, it would stay pretty flat taking 90+mph turns..
let alone any sway bar.. if you werent soo far i would sell it to you.. you could probably get a new one for less than if i were to ship it..with a set of eibach sportlines and junk monroe sensatrac struts and shocks, it would stay pretty flat taking 90+mph turns..
Car: 1987 IROC-Z
Transmission: TH350
I can buy a new one off summit for $140, so you tell me would it be more expensive for you to ship? As to the sportlines and struts, if I change springs I'll be moved to a differant class but I plan on putting konis on my car.
LT1Formula
Oct 8, 2015 08:34 PM
