Accel, MSD, or Pertronix???
Gonna be getting new coil, cap, rotor, plugs, and wires for christmas. Trying to decide what to get. Accel and MSD are always the big name, but pertronix has a nice "flamethrower" tune up kit, that has their coil, cap, rotor, module, wiring harness, vacuumm canister, and all that, and its only $115. Has anyone had any experience with the pertronix flamethrower system? How about accell and msd. I didnt see any kits like that in summit...do they have kits? Where can i get and how much??? Thanks a lot in advance i really need help on this
Hey there, I am in the exact same position as you, only I"ve been looking at the MSD 6A ignition kit w/ the blaster 2 coil system and 6A box for 190$ I think.... Anyways, I want a new ignition for X-mas and don't know which one to buy, so I would also appreciate a reply to this topic, thank you!
84 Z28 HO
62-67 327 block
new 350 crank
.040 overbore
461 double hump heads
2.02/1.60 valves
edelbrock perf RPM intake
edelbrock 600 cfm carb
th-350 tranny
B&M stage 2 Transpak
aluminum roller rockers
489 lift cam
7 quart oil pan
Keith Black pistons
screw in studs/guideplate
84 Z28 HO
62-67 327 block
new 350 crank
.040 overbore
2.02/1.60 valves
th-350 tranny
489 lift cam
7 quart oil pan
Keith Black pistons
I've got the Hypertech coil kit in my GTA from Summit and gave me a SOTP improvement.Its stock black not red like MSD's or yellow like Accel.Performance distribors also make a good kit plus they have a module.
1990 Trans Am GTA
Bosch plat+4 plugs,SLP plug wires,Hypertech coil kit,Fastchip PROM,SLP 160 therm,T-body bypass,SLP crankpulley,Breathless AFPR,,ported plenum,SLP runners,SLP flowbooster,SLP cold air,K&N,SLP 3"catback,SLP torqueconverter,SLP shiftkit,Mobil 1
14.3@96 stock
13.5@102 w/mods
1990 Trans Am GTA
14.3@96 stock
13.5@102 w/mods
I have the Hypertec cap and coil (the one that says danger high voltage on the top) with an MSD module (the one that looks like a cercuit board) in my wifes HEI and it works great. I used to run this disributer in my Nova and put it into my wifes Z when we put the motor in her car. I do not run a box with this system and the car revs clean up to 6000 (I have not had a need to go past 6000 sence both of the motors that it has been in have been very mild). I am planning on getting a MSD6al box for her Z after the first of the year because I want the safty of the revlimiter for her.
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
I personally have the crane cams HI-6S ignition and PS-91 coil i've had no problems with it...not a bad price either for around $160 easy to install as well...the others u named are good as well....just my input
89 GTA
Originating memeber of the SJNEP crew
Rice....it's whats for dinner
check out the car here:
http://www.hometown.aol.com/clarkemustgonow
Tony
89 GTA
Tony
If your car is still computer controlled, the petronix kit will not work. It is for a 4 pin HEI Dist. Good Luck
Black 89 IROC...Mods: 355, 10.5:1 comp, Big Solid Crower Cam, TFS heads, Victor Jr, Holley, and a 5 spd...
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
