Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
need help with aurburn differences
Old Dec 11, 2000 | 04:11 PM
brian86Z's Avatar
is the aurbun pro series that much better then the high performance series? i have a chance to pick up a used high perforance series for 100.00 bucks. my 86Z only has a open rear right now.
thanks
Brian
Old Dec 11, 2000 | 04:19 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
I have an Auburn Pro series in my 88 GTA 350 w/ 3.73's. The HP series is a steal at $100. Get it, but in the long run the Pro Series comes out on top. If you plan to beat on the car on a regular basis, the Pro series is the one for you. The HP series is good as well but the posi won't last as long. It's good for the track and everyday driving. The Pro Series has a higher spring load than the HP Series. I have installed both posi units in similar rears and the springs in the HP are smaller than the ones in the Pro Series. The Pro Series is also about $400. If you ask me the HP is worth it!!
Old Dec 11, 2000 | 04:22 PM
I forgot to mention, make sure you use the limited slip additive from GM no matter which posi you decide to purchase. THIS IS A NECCESSITY!!! If you don't you will be getting a lot of chatter noise from the rear.
Old Dec 11, 2000 | 08:11 PM
theformula's Avatar
That chattering noise is correct. I cant get rid of it. Im getting it right now in my open rear. Im switching to 3:42 posi again 28spline
Even though Joey told me to get the Auburn :B
92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,K&N, Crane AFPR (47psi),MSD6AL, MSD wires, AC DELCO cap/rotor/plugs, Bosch O2sensor, 3:73s,JET fan switch, Macewen white face gauges, Intellitronix Digital Gauges
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
