I am going to replace the injectors on my GTA and I don't want to spend $700 on a set of 8. This is what I was looking at. I will never mod this car. It will stay stock except for the cat back exhaust. These are rebuilt bosch injectors. Will any 22# injector work? These say 305 TPI 85-88. Is there a difference between these and my 89'?
http://cgi.ebay.com/ebaymotors/SB-Fu...spagenameZWD1V
Phil
Phil
if what they say is tru then you have a well matched set of injectors and being bosch brand they shoud be ok all for a decent price. being a F code car you should be running 19lb injectors but iv heard rumor that dual cat cars came with 21s. dunno, this is hear say.
Well your car should have 22ib stock not sure why they say for 305 on the add when they take a 19ib.
305 TPI = 19lbs injectors.
350 TPI = 22lbs injectors.
Ford Racing EV1 (SVO) 19 lbs /hr goes for 213 dollar NEW from summit. These are really nice injectors and when they are set to 39.15psi pressure (as they are made for.) they flow 19lbs so if you got our stock pressure 43psi you get 43/39.15 * 19 = 20,86 LBS/hr with a REALLY good spray pattern because they have a high pressure..
and if you have set your fuel pressure to 48psi you get 48/19,15 * 19 = 23,29lbs/hr..
Alot of guys runs with Ford racing (soon me to, got new ones on the way home..) and they all have good things to say about the.. Just wanted to tell you that new injectors cost $213 not $700
I would prolly buy the ford ones if it stod between the ebay ones and the Ford ones.. heard ALOT of good stuff about the ford ones.
..I would prolly buy the ford ones if it stod between the ebay ones and the Ford ones.. heard ALOT of good stuff about the ford ones.
i just finished installing ford injectors on my car, used the o-rings that came with them and had no problems. i paid $200 new for 24lb
