FUEL PUMP ???
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
FUEL PUMP ???
o.k. , i have some more troubleshooting to do . but , i fear i am looking at the dreaded fuel pump change . since i only want to do it once what is the best recommended replacement & source ? the car is a 91R/S 305 TBI , t-5 , headers & minor mods. . cost , ( within reason ) is not a factor .
Re: FUEL PUMP ???
well it seems no one has an opinion . i have checked locally and found bosch & airtex . bosch quality i understand is not that great anymore . anyone know about airtex ? i have found their #'s mixed in with A.C.delco & GM . i am leaning towards airtex , any thought's on this ?
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Re: FUEL PUMP ???
WHATEVER YOU DO, DO NOT BUY AN AIRTEX FUEL PUMP. if you only want to do this once. i put an airtex pump in my camaro and a month latter i was back in there replacing it. I would buy the bosche one or an aftermarket one. but NOT the airtex one.
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
Re: FUEL PUMP ???
I just installed an ACDELCO from rockauto. I used the 5.7L pump and it works fine, plus you have a little extra if you do any upgrades in the future.
Car: DAF
Engine: 3 cyl 2 cycle
Transmission: variable speed
Re: FUEL PUMP ???
Most all aftermarket pumps are made by TI. Walbro, Marwal, and TI Pierberg might be on the pump. Airtex/Master buys most of their pumps out.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
