Sub-Frame Connectors
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
I am planning to install sub-frame connectors as soon as I make up my mind wich ones I want. I am leaning towards the UMI brand but also like the BMR ones. Hoping to hear all the pros and cons on them or any other ones that work good and fit right
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Sub-Frame Connectors
First...Welcome to the board.
There are LOTs of threads on this if you do a search.
Both are very good brands. Comes down to preference.
My suspension is all UMI (sfc, panhard rod, lca, wonderbar) and I'm quite happy with them. The sfc's are VERY beefy and solid. ALso, the guys at UMI are great to deal with.
Choice is yours.
Choice is yours.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Hello
Thanks for considering UMI Performance for your suspension needs. We do offer a weld on version what have been tested and proven. They work on all styles such as T top, Convertible, And hard tops. And when you purchase from UMI Performance you are not only getting a great quality product. But its also made right here at our own facility in the USA.
If you have any other questions feel free to ask.
Brad
Brad
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I bought a set of BMR's for my car. I need to get off my *** and install them. I've got the welding equipment, but I have never welded anything with MIG before. I need to practice before jumping into that.
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Im going to pick up a pair of jegs subframes, theyre pretty affordable, im going to try to tig weld them, ill see how that goes.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The BMR n Alston SFC is the way id go Id I had room for both, links is post above.
They are a match made in 3rd gen heaven till someone offers a complete kit like that.
I went with the Alston bolt in / weld in from Dough Herbert Racing $190 shipped.
Even better then Alston prices.
Engine: gone
Transmission: gone
Axle/Gears: gone
well i like UMI products and SPOHN products but you can order UMI products through summit and it saves quite a bit on shipping!
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
Thanks for the links! I came across them shortly after posting this and realized I didnt search other ereas before asking ( like I have seen sugested by so many). so thanks for responding . FYI I am going to go with my gut and order the UMI from summit and weld them in and decide later wether or not I can clear the double frame connectors as shown in the links THANKS.
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Will UMI's work with the SLP exhaust system? I have been under there quite a bit lately and there isn't a whole lot of room! Thanks!
Car: 89 IROC
I have dual cats and an SLP loudmouth exhaust.
Car: 1989 i roc-z28
Engine: 350 tpi l98
i use alstons and love them. the tighten up all the wide fender gaps and the handeling inproved a ton. even my passangers can tell a difference when i drive it. the car feels more solid and like a lot of people say on here SFC should be the first mod on any thirdgen
Car: '88 Camaro (Gone...)
All I can say, is dang UMI's subframe connectors are HEAVY. To some people that = beefy/strong, to others it's extra weight your car has to lug around. Can't compare the weight to other brands from my experience though
You want your sfc's to have some weight to them.....as opposed to aluminum. Supreme Member
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
TMZIrocZ350
Oct 7, 2015 12:09 PM
tmork454
Sep 29, 2015 06:33 PM
