hey guys, which would you choose? I have the choice of going with a used DFI unit or calling TPIS and getting their level VI chip for the same money. Which is better?
Also, if I get the DFI, what happens if you get a jump over harness that does not take care of the fuel tank pressure purge valve and ac and cruise control....is it critical?
thanks
Steve
thanks
Steve
DFI or chip? That's like Corvette vs. Chevette!
Go DFI. I have my DFI installed directly with NO jumper harness/plug-n-play stuff. Dash works fine, a/c works, etc. Just have it installed by an EMIC that knows what they are doing. I think Turbo People is near you. Check Accel's website...
Old: 1989 Formula, 383", DFI, built 700R4, TFS heads, Mini-Ram, Vortech S-trim 15 psi, 3.70 gears
Best ET: 10.796 @ 125.8 mph
New: 1989 T/A, 406", Accel Pro-Ram, DFI, AFR heads, HRC Turbosystem, NOS 150-hp dry kit, TH400 w/GV overdrive, 9" w/3.70 gears, 8-pt. S&W rollbar, 18" wheels
Best ET: Spring 2001
Employed at:
Hahn Racecraft
Accel EMIC/DFI Tuning
Turbosystems & Custom EFI
Member of Midwest F-Body Association www.mfba.org
Employed at:
Hahn Racecraft
Kevin91Z
close
- Join DateJul 1999
- LocationOrange, SoCal
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1990 Pontiac Trans Am
- Engine355 TPI siamesed runners
- TransmissionTremec T56
- Axle/Gears12-Bolt 3.73
- Liked:26 Times in 22 Posts
DFI is digital fuel injection. Check Accel's webpage at www.mrgasket.com/accel.htm
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
I've already responded to this in another post, but BURN YOUR OWN!
The equipment to burn your own chip is cheap: $130 for the Pocket Programmer (my preference), $40 for the UV Eraser and $70 for Editor (I like Tuner Cat for the SD 730 ecm). $240.00 that's it.
You might also want to consider a scan tool if you do not have one. But it is not an absolute necessity and should NOT be the only method of evaluating a chip. Also, it is not as useful on slower ecms or ecms that do not give as much information. A scan tool just helps you get "close" quicker on the later (and faster) ecms, but it is not a necessity.
