[DE] Parting Out 1985 Trans Am TPI 5 Speed 3.23 R. Disc
Old Sep 30, 2015 | 07:41 PM
KO1's Avatar
KO1
Mostly complete, t tops, 9 bolt posi w 3.23s and disc brakes, 88 roller 5.7 engine supposed to be rebuilt very very clean inside, TPI intake , harness ECU w 2 different Hypertech chips, rebuilt T5
Old Sep 30, 2015 | 08:32 PM
xbazzarex's Avatar
Car: 1985 T/a, 1988 Formula
Engine: LB9 and LO3
Transmission: 700R4 and 700R4
Axle/Gears: 9 bolt 3.27, unknown
Re: Parting Out 1985 Trans Am TPI 5 Speed 3.23 R. Disc
where at in de? and how much for the front bumper cover. also how are the rims and tires?
Old Sep 30, 2015 | 08:43 PM
KO1's Avatar
KO1
New Castle, no body parts or wheels tires
Old Oct 1, 2015 | 06:25 AM
chevyrules2's Avatar
Want a title? Post!
Car: 1978 Chevy C10
Axle/Gears: 3.70
how much for the lower intake and the ride 32680
Old Oct 1, 2015 | 09:15 AM
KO1's Avatar
KO1
the lower intake is from an 88
Old Oct 1, 2015 | 10:20 AM
KCG's Avatar
KCG
Car: 89 IROC
Do you have a Thermostat housing off TPI manifold?
Old Oct 1, 2015 | 10:25 AM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
How much on the 9 bolt?
Old Oct 1, 2015 | 11:33 AM
Cardoctor383's Avatar
Car: 92 gta
Engine: Supercharged 355
Transmission: T56 6speed
Axle/Gears: 373
Very interested in the 5 spd shifter plate if it's available
Old Oct 2, 2015 | 11:32 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Do you have the entire parking brake cable? I need the beginning of the cable on the lever all the way to the seperate wheels
Old Oct 2, 2015 | 02:35 PM
ivan1137's Avatar
Car: 1989 Trans Am
Engine: 5.0L V8
Do you happen to have the upper dual fan radiator cover?
Old Oct 2, 2015 | 05:14 PM
Want a title? Post!
Car: 1978 Chevy C10
Axle/Gears: 3.70
Do you the throttle cable and bracket?
Old Oct 14, 2015 | 05:39 PM
brist's Avatar
How much for complete tpi intake ECU and harness shipped to 56763?
Old Oct 14, 2015 | 06:59 PM
KO1's Avatar
KO1
$400
Old Oct 15, 2015 | 03:29 PM
instaldave's Avatar
Car: 1987 Trans AM
Engine: 355 4-bolt, L98 heads, Holley 650DP
Axle/Gears: 3.70 9-bolt
Is the speedometer cable? If so, how much for the cluster? Is the dash pad in good shape?
Old Oct 15, 2015 | 04:57 PM
KO1's Avatar
KO1
$350
Old Oct 15, 2015 | 04:59 PM
KO1's Avatar
KO1
single fan car
Old Oct 15, 2015 | 05:00 PM
KO1's Avatar
KO1
yes it has a cable speedometer, I need to check the condition of the cluster
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
1992Z28!
Nov 19, 2015 07:33 AM
Numbah-1
Sep 12, 2015 08:57 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
