Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Window Weatherstrip Replacement?
Old Sep 29, 2010 | 04:48 PM
V8-Z28's Avatar
Hello,
I am currently replacing the weatherstripping along the window of my 82' Z28. I took the door panel off and replaced the exterior strip (which was held on by some screws). But the interior strip looks as though it is molded on to the plastic part that runs the top length of the door on the inside. What is the process for replacing this interior window strip?
Old Oct 1, 2010 | 03:24 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Window Weatherstrip Replacement?
unfortunately, as you're seeing, that seal is plastic welded to the upper plastic panel. if you have the tools, you can grind down the plastic "rivets" that hold the parts together and then use a plastic welder (or some sort of adhesive) to get the parts back together.
if the task sounds too daunting, we do offer the sweeps with the upper mouldings pre-installed together
inner sweeps
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
pfsteichen
Feb 9, 2016 06:59 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
