Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Question on heads
Old Sep 23, 2000 | 12:53 AM
GTARob's Avatar
Question on heads
I am having a 350 built to swap into my 305 GTA. I have located a used, ported and portmatched(at lingenfelter) Superram for the engine. I was thinking of going with the Lunati full roller equivelant to the Lingenfelter 319 cam. My machinist is a lunati dealer and can get me a good price. Here's the question;
Will the heads off of a stock 350 ported and port matched to the intake be able to flow enough to take full advantage of the the induction and cam? Also I have heard of people takeing corvette heads and using them. Will the mount up to the Super Ram? What casting numbers should I look for and out of what year model? Anyone with a similar setup please respond and help me out. What kind of power are you guys geting out of the motors? I will also be putting an MSD 6a box with the Timing retard controller along with the an MSD coil. The exhaust will be going through SLP headers. The rest will have to remain stock for now.
1989 GTA TRANS AM
305 TPI, 5 SPD
SWAPPING TO TPI 350 NEXT MONTH.
Old Sep 23, 2000 | 10:52 AM
Guest
Guest
Posts: n/a
Are you on a budget here? If so I'd just stick with the stock 350 heads and have those ported unless you found a good deal on some vette heads somewhere. They used the aluminum vette heads from 87-up, plus the 86 convertible had them.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
