Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
FOUNDERS LCA relocation brackets
Old Dec 31, 2014 | 04:37 PM
  #51
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: FOUNDERS LCA relocation brackets
Here you go. Look at the bottom of post #5, and it shows the Jack handle and ratchet extension I used to make the holes line up.
http://ltxtech.com/forums/showthread...r-End-Upgrades
You'll get it on there!
Old Dec 31, 2014 | 04:45 PM
  #52
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
I can't see the pictures on that site. I guess maybe you have to be a member? Anyway, my holes are waaaaay off. I tried my best to line them up with everything loose and a pry-bar and jack handle. I'm guessing the Founders product is made to a much more exact specification than the sloppy construction of the 80's era GM product. I think I'd have an easier time just plugging the hole and re-drilling it. My thought is to weld up the bracket on the rear end and re-drill since the shock probably doesn't need to be as spot on as the LCA's do. Thoughts?
Old Dec 31, 2014 | 04:51 PM
  #53
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Dang how far off is the hole? Mine was about 1/16" off
Old Dec 31, 2014 | 04:52 PM
  #54
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
at least 1/2 inch. I can probably persuade it about 1/4 inch, but 1/2 inch is asking too much.
Old Dec 31, 2014 | 05:00 PM
  #55
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Try using the jack handle and ratchet extension and persuading it that way. It took me a good long while to get mine to line up.
Old Dec 31, 2014 | 05:02 PM
  #56
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Put the ratchet extension's square end in the hole first, then slide the jack handle over it, then work the bracket with it.
You could duct tape it too to keep it from slipping off.
Old Dec 31, 2014 | 05:06 PM
  #57
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
It's just not gonna happen. It would have to come over and down 1/2 inch. I can get it to flex over but not down. I think I'm pretty strong, but I don't think my kung-fu is good enough to bend and stretch metal.
  #58
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
My whole rear was up on saw horses, which made it easy to work the "tool" around.
If you weld the bastard in place, I suppose it wouldn't matter about the bolt hole not being perfectly round on both the stock shock mount and the bracket, as long as you only drill the Founder's bracket. :IMO:
Old Dec 31, 2014 | 05:09 PM
  #59
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
mine is out of the car too
Old Dec 31, 2014 | 05:11 PM
  #60
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
on a motorcycle jack
Old Dec 31, 2014 | 05:12 PM
  #61
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Old Dec 31, 2014 | 05:14 PM
  #62
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
I mean only elongate the hole on the Founders bracket.
Old Dec 31, 2014 | 05:16 PM
  #63
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
I was suggesting just welding the hole shut on the rear end, then put the bracket in place to find out where the a new hole should be drilled to line up with the Founders bracket.
Old Dec 31, 2014 | 05:18 PM
  #64
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
this way nothing needs elongated. Both holes would line up perfectly. But the shock would be 1/2 inch off from it's original position where it mounts to the rear end. I'm guessing 1/2 inch shock adjustment would not cause any problems.
Old Dec 31, 2014 | 05:20 PM
  #65
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
I wouldn't do that. Just drill the founders bracket hole to make it so the threads will go through and then the nut will tighten the shock and bracket. Then I'd weld the founders bracket to the axle tube's bracket. The founders bracket will then be in place and the shock location will be where it's supposed to be.
Old Dec 31, 2014 | 05:23 PM
  #66
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
The elongated hole in the founders bracket won't matter if the bracket is welded to the axle tube bracket.
Old Dec 31, 2014 | 05:25 PM
  #67
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Hell the elongated hole might not even matter if the bracket ISN'T welded in place.
  #68
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
I'm reluctant to weld the brackets on just in case I choose to put the car back up to stock ride height at some point.
Old Dec 31, 2014 | 05:26 PM
  #69
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
To me, changing the position of the lower shock mount doesn't sound like a good idea.
That's just me though.
Old Dec 31, 2014 | 05:29 PM
  #70
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
I'd bend the bastard with my "tool" as much as possible then just drill out the rest and keep the factory shock mount hole in the same place.
Old Dec 31, 2014 | 05:33 PM
  #71
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
I'd bet every one of these cars is slightly different in where the brackets were welded on to the rear end.
F@#* it. I'm turning on the gas and doing some welding.
Old Jan 5, 2015 | 09:17 AM
  #72
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
I would suggest welding them on. I just cut mine off last weekend and added the Racecraft prostock brackets to help with ride height and add more adjustability.
I had to cut the 2 hole bracket since it was hitting the inside of 15x12 rim. The new brackets hold a 3/4 rod end and do not extend as far to the rim. Otherwise, there would be no room for anymore holes.
The two hole was good enough for 1.17 60's on the rear tires.
Old Jan 6, 2015 | 01:26 PM
  #73
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Mine fit fine.
I welded them also.
Old Jan 6, 2015 | 03:51 PM
  #74
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Originally Posted by greenyone
This is an old thread but... I just got my Founders LCA relocation brackets and I'm having the same issues with one of the shock mount holes lining up to the bracket on the rear end. I was thinking of welding up the hole on either the Founders bracket or on the rear end bracket and re-drilling the hole. Does anybody see any issues with this? Would you re-drill the new bracket or the mount on the rear end?
Mine were a super tight fit, I thought there was no way they were going to go. I had to do a little persuasion with a pry bar but then then fit perfect. There is no slop in the holes on the founders brackets.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
