Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Headlight Conversion Help
Old Feb 10, 2013 | 03:53 PM
shermro99's Avatar
Car: 1984 Pontiac Firebird
Engine: 305, 5.0L, V8, CCC
I have a 1984 Firebird 305 5L. and I bought theses lights: Halogen Semi Sealed H4 Crystal Clear Glass Headlights (60/55W). The website says that they are plug and play but they are dim. I have been searching all over and some threads say "get a relay harness" and others say "change the head light connector pins 1 over clockwise, because the H4 light bulbs are wired differently". I am so confused and not sure what is the right approach.
Please help me out.
Thank you!!
Old Feb 10, 2013 | 05:29 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Headlight Conversion Help
Maybe you need the harness that is plug & go.
calgutie
may be a more direct help.
Old Feb 10, 2013 | 09:05 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
calgutie
either will work. the relay harness method will make them brighter though. The plug and play harness is just a harness that already has the pins swapped over. i built my harness in a few hours if thats any consolation.
Old Feb 11, 2013 | 12:28 AM
shermro99's Avatar
Will the plug and go make them a bit brighter too? Right now they look very dim. I have not done any pin changes to it.
Old Feb 11, 2013 | 01:01 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Compared to what you have yes. Your lights are not operating properly, swapping the pin or buying the harness will yield the same result. If you do a relay harness you're putting more power to the lights which will make them brighter than normal operation
Old Feb 11, 2013 | 08:07 PM
shermro99's Avatar
Thank you BluFBd and t-top havoc for helping out. Much appreciated!
Old Apr 21, 2013 | 06:13 PM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Perhaps they need the balast component as well?
I just purchased a kit with the wiring etc, and they coem with two powerpack looking things that I'm assuming convert and power the lights.
Linson
Oct 24, 2025 02:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
