Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
help!!
Old Mar 30, 2014 | 12:41 PM
patriots781's Avatar
Car: firebird 91
Engine: 350 5.7 small block
Transmission: turbo transmission
help!!
I got a saginaw style ps pump almost identical to the previos one I got a pulley too but I have no bolts the pump didn't come with it so the previous is pushed on I got the pulley remover this pump is ancient sprayed pb everything nothing so can anyone please tell me what screw bolt washer I'm looking for I can figure out size but have no idea what I'm lookin for hekp???
Old Mar 30, 2014 | 03:26 PM
joshc's Avatar
Car: 1986 Trans Am
Re: help!!
You would probably get help faster if you post in the appropriate topic group and put a little more descriptive title.
Old Mar 30, 2014 | 08:08 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: help!!
If your are ultimately unable to locate the proper fastener, you could always return that pump (with bolt on pulley) for the same design as you have (press on pulley), then take them to a machine shop and have them switch the pulleys for you. Just a thought, as it seems your a little desperate to get this resolved.
