Vevor Air Jack
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Vevor Air Jack
Short test right after assembly Unfortunately, it wont fit under the x-member. The jack pad could be a little larger/thicker. It wobbles a bit at full height, but only if you bump it. The bend in the tube make the handle want to tuck into the bumper. So ima take the bend out and make it straight. I like it so far. Time will tell. Was eyeing these for some time and amazon had them on sale recently.
rsrsrs
May 21, 2007 03:07 PM
