damaged MSD fleabay
Car: 89 trans am GTA
Engine: 355
damaged MSD fleabay
so i just got it in today and the pin that would run to the gray wire has been pushed back into the box.
my question is. does anyone think it damaged the internals? does my application need the gray wire?
1989 trans am TPI 5.7
i would like to use the built in security function but eventually will switch to an MSD distributor so using the green/purple wire would later become an issue
edit: got an MSD 6AL 6425 with coil and splice harness
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Re: damaged MSD fleabay
You can send that to MSD and they will R&R the box for a nominal fee.
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
There are fake MSD being sold.
The serial number is something like
60138 60813 60318
Or something like that, but def has 6 as the first number.
If yours starts with 6 then def call MSD direct for evaluation of your serial number.
( edit )
682013
Fake MSD
60138 60813 60318
( edit )
682013
Fake MSD
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Here is some info about the MSD bankruptcy... MSD Performance Files Chapter 11 Bankruptcy, We Find Out What's...
Engine: LB9 | LS1
RedLeader289
May 28, 2019 01:47 PM
no green
Jan 9, 2016 09:22 PM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
