Aftermarket Vendor Review Provide questions and comments about aftermarket part vendors for the Third Gen F-Body.
Help me MSD tech!
Old Dec 9, 2001 | 05:01 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
Help me MSD tech!
i had an MSD 6AL in my 89' formula 350... now that the car is gone i might as well set it up in my 85' i know that msd makes a harness for the newer style ignition.... but what about my 85'? i dont want to have to splice any of the factory harness.
Bone stock blue TPI 85' Z28 42k original miles.
My Ride ---> https://www.thirdgen.org/rides/index...ew&rideid=8141
*previous car: lightly moded 89' Formula 350
Old Dec 10, 2001 | 12:01 PM
MSD tech's Avatar
Yes we do, but I am about to show my lack of knowledge of mid 80's Camaros. If you have an external coil, using the small distributor then the plug in harness is part number 8876. If the distributor is the large HEI with the coil in the cap, (like the Corvette's) then the plug in harness is part number 8875. I am almost positive that it is the small cap external coil set up but I don't want to mislead you.
Thanks,
Joe
MSD tech
Old Dec 10, 2001 | 02:03 PM
no... its the one w/ the coil on the cap... but you have a harness that works for that? i had the external on my 89'... also... can you give me some info on tach adapters
Old Dec 11, 2001 | 10:30 AM
MSD tech's Avatar
Then the harness is part number 8875 and if you want it the coil it is part number 8225. Your car will not need the tach adapter. If the tach does not function with the box in place there is a tach filter in line on the tach wire that will need to be by passed. This will allow the tach to function with out any adapters.
Thanks,
Joe
Old Dec 11, 2001 | 10:37 AM
thank you very much
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
