Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
DIY Intake parts
Old Apr 15, 2005 | 12:36 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
DIY Intake parts
Some DIY efi parts...
Intake Manifolds: (verrified to work)
http://store.summitracing.com/partde...=KeywordSearch
Fuel Rails:
Fuel Pressure Regulators:
Junkyard stuff:
Vortec Throttlebodies are monoblade, 75-80MM
Grand PRIX fuel pressure regulators work great, and the
lines can be flared.
Old Apr 16, 2005 | 10:51 AM
Guido's Avatar
Car: 2000 Trans Am
This will work too
http://store.summitracing.com/defaul...=KeywordSearch
Old Apr 16, 2005 | 11:47 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by Guido
This will work too
Thats the first one in my list
I shoulda used the Victor Jr. on mine, rather than the street dominator, but it was one of those situations where it was available, and the whole conversion cost me less than $300.
-- Joe
Old Apr 16, 2005 | 12:26 PM
Guido's Avatar
Car: 2000 Trans Am
The first one in your link is just the carb version. The one I posted is already machined for injectors.
Ive got a strip dominator sitting at home with holes drilled in it for EFI bungs but I never got around to doing it. LOL
Old Apr 16, 2005 | 12:48 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Hi guys. I know both of you have converted manifolds to work with EFI. Would either of you be interested in listing the procedures for a DIY EFI intake?
Old Apr 16, 2005 | 12:55 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm confused. They both come up as EDL-2975 .. ??
Strip Dominator is a nice manifold.
-- Joe
Old Apr 16, 2005 | 12:56 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I did a step by step post when I did mine. I just moved it here from diy_prom, and stuck it.
I'll edit it if there is some missing/relearned info.
-- Joe
Old Apr 20, 2005 | 09:12 PM
onebinky's Avatar
I used a Vic Jr, ROSS Machine injector bungs, a 70mm TB off of a 2003 Mustang GT, and used the stock rails with some mods. Stock regulator drilled and tapped for NPT to AN fittings. I am only using one inlet into the regulator, so I enlarged the opening into the one and plugged the other so I can maintain a normal pressure.
My dad TIG'd the bungs in for me, the fuel line fittings are a mix of Russel, Aeroquip, and Summit. -8an pressure line, -6an return line.
ANESTHES: I finally have the intake the way I want it, I'll try and submit some updated pics to your website and your main thread within a couple days.
I also found those motor mount shells yesterday if you are still in need.
Old May 17, 2005 | 09:52 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
They are listed on anesthes site. I am in the process of doing a conversion and write up now. I am just stuck on what throttle body I want to use.
Old Aug 29, 2005 | 04:57 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
-- Joe
Believe he meant 29785:
Old Sep 16, 2009 | 11:14 AM
charlie 1's Avatar
Re: DIY Intake parts
what kind of points distributor would you suggest using, with these intake and what year did one come in a v-6-60 engine
Old Nov 14, 2009 | 12:42 PM
Killerzracing71's Avatar
Any updates on this thread, im in the planning procces of my intake now.
Old Nov 14, 2009 | 03:42 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Done the holley twice. Good for a 1205 intake.
Next intake will probably be victor just because I have not had my hands on one.
-- Joe
Old Nov 14, 2009 | 09:28 PM
-- Joe
Oh okay, the intake im going to grab is this one.
http://www.summitracing.com/parts/PFS-52033/
Im more worried about the regulator.
Any more info on the one from a GTP?
I can get my hands on some SSEI regulators. 50psi is stock pressure.
What mods were needed to get a factory L67 reg to work?
Old Dec 7, 2011 | 06:15 PM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
http://www.summitracing.com/parts/PFS-52038/?rtype=10
just installed one of these on a 406 small block. Its real tall with VERY large runners. A lot like the old bowtie intake. Its a nice piece, regardless of its manufacturing location.
If you shop around you can get one for about $200.00 unpolished.
For fuel rails I have twice bought rails from a guy on ebay that sells blank fuel rail for $11.00 per foot.
Throttle body, 80mm Q45 monoblade with built in soft progressive roller cam linkage, nice piece and REAL easy to adapt, pick-n-pull for $35.00.
1992 Trans Am
May 10, 2023 07:19 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Catcher55
Aug 15, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
