Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Fuel Pressure going real high when trying to start
Old Jun 3, 2005 | 11:14 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Just finished up my stealth ram install.
I plumbed the fuel rails with braided. The lines from the rails go into a Magna Fuel FPR, which then goes into the return hose.
When trying to start the engine, the fuel pressure gauge on the reg. burys. It is a 60 psi gauge.
If the car sits for a few minutes, the gauge will read about 40 psi, overnight, it goes back down to 0.
The car is not starting ,but I think the dist. may be 180 out. I am going to check that tonight,.
Just a little concerned about this fuel pressure being so high.
Is this normal?
Old Jun 3, 2005 | 03:39 PM
Car: 1971 Camaro
Engine: 427
Anyone?
Old Jun 3, 2005 | 09:13 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Is this an adjustable regulator? If so I'm guessing it might be set too high. Also, what kind of fuel pump are you running?
Old Jun 4, 2005 | 08:02 AM
Car: 1971 Camaro
Engine: 427
Well, when all else fails read the directions. I dug it out and it said the pressure must be set with the car running. Its okay now.
Car is running too! Distributer was one tooth off.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
killer777
Aug 8, 2015 02:47 PM
