Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
LT1 intake with speed density i have a question
Old Sep 6, 2005 | 12:39 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
do we need computer changes with Speed density if we just swap this intake?
also what is the stock LT1 fuel pressure setting with the stock FPR? i will eventually switch to an adjustable but right now im using the stocker.
Old Dec 22, 2005 | 08:53 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
not sure about the factor fuel pressure for an LT1 motor maybe someone eles can enlighten
With a SD system to see it's full potencial(sp?) you really need to change the tuning.a MAF system is alittle more forgiving with changes to how air gets in and gets out.even then to see it's full potencial you still need tuning.
Old Dec 23, 2005 | 02:58 PM
Z69's Avatar
Z69
Depends on what you start with for a prom.
The stock 92 fbody 350 tpi is a little rich above the stock torque peak.
So people end up being "ok" on top. But end up being rich below
about 2800 with the LT1 intake.
What prom do you have now? The only close to drop in stock prom for a MT would be a vette prom.
Are you doing your own chip?
midge54
Dec 27, 2019 04:14 PM
Steve78LT
Feb 24, 2016 12:15 AM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
86Base
Aug 8, 2015 01:34 PM
