Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR fuel lines pics, best cam & inst. manual?
Old Oct 26, 2005 | 01:55 AM
socal85tam's Avatar
Car: 1988 IROC-Z
Engine: 383 HSR
Transmission: 4 speed Automatic
Axle/Gears: 4:10
I just received my HSR intake, I bought it used, and have been searching all day for an installation manual, [B]and pics of the fuel lines setups[B/], without luck. Where can I get the complete manual?
I was wondering if anyone has routed the fuel lines in the front of the intake. I also would like to know how to install the fuel pressure regulator.
Last question, if you hava a HSR what is the cam you are using, I would like to swap my cam when I put this intake.
I have a 383 with TFS 195 heads and 214, 220 cam. My diferential ratio is 3.73.
Please post pics of your fuel lines routing, specially ones routed to the front of the intake.
Old Oct 29, 2005 | 12:35 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
http://www.stealthram.com
Old Oct 30, 2005 | 12:51 PM
redandblack's Avatar
just run something with a mild duration....230-240is and something with a lot of lift...like .560+ u will make good numbers
Old Nov 19, 2005 | 12:01 AM
57TUNED's Avatar
Car: 88 iroc
cam
i have a cammotion cam custom ground for hsr and 195 afr heads though made good power for me. full weight iroc went 11.61 at 117 with 3.73 gear
here are the specs at .050 intake 233 exhaust 246 intake lift with 1.6 rocker .571 exhaust .591 intakecenterline 111.9
i have the cam for sale went with a solid roller
Old Nov 19, 2005 | 12:45 AM
yeah that would be a good cam for a 350 hsr setup. so ur going with a solid roller cam too.......may i ask what the specs on the solid roller cam are?
Old Nov 19, 2005 | 12:58 AM
57TUNED's Avatar
Car: 88 iroc
cam
manifold changed to accel proram new cam .050 i 260 ex 266
lift intake .651 exhaust .642 on a 110.9
Old Nov 19, 2005 | 01:16 AM
why would u get a decent cam like that and go to the proram? just wondering....u would make better power with the hsr
Old Nov 19, 2005 | 12:13 PM
57TUNED's Avatar
Car: 88 iroc
more power with proram better rpm range
Old Nov 19, 2005 | 06:34 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I wouldn't think you would want to route the fuel lines into the front. That will cause the regulator to not be the last point in the circuit. If you get a hot day the possibility of boiling and getting "air locked" on 1/2 of one rail .
the way I see it the fuel is pushed all the way through both rails before exiting via the regulator. That would purge any air very quickly. Will help if you ever run out of gas.
Isn't that why bypass systems came into use?
Don't know if it really matters for the few cycles it may take to get those couple of cylinders to fire on vapors. The air "should" go through the injectors at some point.
Anyone had experience running fuel lines into dead end rails?
Would clear that up for me anyway.
Old Nov 19, 2005 | 07:53 PM
thirdgenrs's Avatar
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
Axle/Gears: 10bolt 3.42/posi
www.holley.com has instruction manuals as well.
Old Jan 1, 2006 | 03:21 PM
Crisis's Avatar
I ran my lines to the rails for the back. The rails were the end of the circuit and I had no problems.
Crisis's Avatar
Old Feb 4, 2006 | 10:09 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
FYI heres a pic of my fuel lines that i cut down on the frame rail. they just run to the back of the motor...nice and concealed
Old Feb 4, 2006 | 11:09 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Nice, so you got that accomplished? How hard was it?
Old Feb 4, 2006 | 11:13 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
yea finally got it. like most things on the car ive found out it isnt hard at all. once you understand what you need to do (mainly i had to learn all about the AN fittings) its not bad.
i did have to buy the 37 degree flaring tool and a couple attmepts at getitng the correct fititngs but piece of cake!
i would recommend anyone swapping a HSR to get on their backs, cut the lines down on the framerail somewhere and make nice braided lines
Old Feb 6, 2006 | 06:49 PM
zrated383's Avatar
Car: '88 IROC-Z
Engine: StealthRammed 355
What fittings are those and what is the tool you used? I would like to do this. Also, is it possible to just run a braided line right from the inline fuel filter for the feed line?
Old Feb 6, 2006 | 09:00 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
you need a 37 degree flaring tool, tube nuts and sleeves (-6AN feed, -5AN return), -6AN male to male adapter, -6AN male to -5AN male adapter, what ever hose ends you want to use (i used 4 straight ends), and of course braided hose.
you can run braided line from whereever you want but i dont know what fittings you would need to install directly onto the filter.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
