Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Modified LT1 question
Old Nov 23, 2005 | 08:18 AM
ascalise's Avatar
Car: 91 Z28
Engine: 357ci. 292xfi, 220/64, Victor Jr.
Axle/Gears: 4.10
I bought a modified LT1 setup from someone and recieved it yesterday. The TB bores were ported a little and the middle section was cut out. The little passage that i'm assuming is used for the IAC was cut into and is no longer isolated. Will this make any difference in performance, idle, or vacuum?
Old Nov 23, 2005 | 12:19 PM
Z69's Avatar
Z69
It may affect idle as it ported the IAC to each runner.
The rear cylinder may run lean at idle.
Old Nov 23, 2005 | 07:50 PM
ascalise's Avatar
Car: 91 Z28
Axle/Gears: 4.10
Would you happen to know if the the HSR and miniram requires a LT1 or TPI TB? I am probably going to send this intake back and keep the throttle body. It came with a bbk 58mm TB. How can i tell the difference between a TPI and LT1 tb?
Old Nov 25, 2005 | 09:00 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Easy, just by looking at them. The LT1 TB has a different throttle cable cam, different IAC housing, IAC sensor and TPS sensor.
If the TB is stripped down it is more difficult to tell the difference.
Old Nov 29, 2005 | 10:20 AM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
All the TPI and LT1 tb's will bolt up the same way. What you want is the correct TB for your car...
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
