Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Can a HSR support this?
Old Nov 29, 2005 | 10:23 AM
vwdave's Avatar
I am in the process of purchasing a set of AFR 195 heads with the competition CNC porting. This on a 350 (or 383) and a XE276HR cam.
Bottom line is, can the HSR flow enough air to support those heads? Or do I have to get a single plane and try to convert that to MPFI?
(Or just go carb)
Old Nov 29, 2005 | 10:39 AM
Z69's Avatar
Z69
www.stealthram.com
The 276 isn't big enough to tax your heads anyway.
Or the HSR....
Old Nov 29, 2005 | 08:10 PM
AZ406TPI's Avatar
Car: 1986 IROC-Z/28
Engine: 406 CID SBC
Transmission: 700R4 A4
what about same heads (well, AFR's, but 210s) on a 406 with a HSR ... would a CCA-08-306-8 (290/307, Lift .510/.540) be good? not looking for gas milage.. looking for the best cam from around 2500-6500 rpms and likes nitrous.. alot (250 shot)
Old Nov 29, 2005 | 08:27 PM
vwdave's Avatar
Well, I do have 1.6RR's, so that makes it slightly more aggressive, but yeah.
I am hoping for about 1whp/cubic in. Basically 350whp for a 350 or ~400whp in a 383.
I do also have a 150 shot laying around....
Old Nov 29, 2005 | 10:52 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
HSR flows like 275 cfm down each runner....teh AFR heads flow 265 through each runner so.....yea.....the HSR will do just fine and people on the www.stealthram.com forum have that setup and it works really well.
Old Nov 30, 2005 | 05:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
on a 383, i would go xr280 or whatever that cam is with 230/236 degrees with those heads and intake.
its what i plan on doing. i think it will make peak power near 6000rpms. which is all the higher i want.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
Briandrex
Oct 5, 2015 06:20 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
