Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
383 HSR Temp switch and thermostat?
Old Nov 23, 2006 | 12:40 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I have a 383 that Im putting together....its got the HSR on top....you guys with a HSR ...what temp switch and thermo stat are you using?
Old Nov 23, 2006 | 08:10 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I'm using a 180-degree thermostat (same as with the SLP runners and Edelbrock base) and have the fan to come on around 190 degrees. I don't have a fan switch for the other fan, just a manual switch on the dash.
Old Nov 23, 2006 | 08:50 PM
yeah but Im lookin for HSR's....you got TPI....
Old Nov 25, 2006 | 08:27 PM
Engine: 385 HSR
Looks like I need to update my sig. I installed an HSR this summer...
Old Nov 25, 2006 | 09:24 PM
AHH??!!!..gotcha..180 huh?..so you likin the HSR? what you running?
Old Nov 27, 2006 | 08:27 AM
Engine: 385 HSR
Yep, 180 degree stat. I like the HSR so far, but haven't been out to the dyno or track yet. Car should be out of the body shop soon...
Old Nov 27, 2006 | 09:30 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
180* t-stat
Old Nov 27, 2006 | 11:27 AM
what about temp switch? what temp switch you running with the 180 stat?
on a side note....Yen!...my AFR heads come in today...been waiting since I ordered back in July...I'll get some pics when they come in...CANT WAIT!!!
Old Nov 27, 2006 | 08:31 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I don't run one...I have a stand alone unit for the fans. 190* would be good for the temp switch.
We want pics on those heads! You wouldn't want to trade for 180cc AFRs would you....j/k.
Old Dec 2, 2006 | 03:40 AM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
i have a 180 degree thermostat and i have a manual adjustible fan control. i ahve it set around 190 or so. Depends where i'm running around town or at the strip. so i can adjust from under the hood.
Old Dec 20, 2006 | 12:55 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Old Jan 5, 2007 | 12:15 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
kinda late, but I am using the thermostat housing from a 90 TBI car with plugs in the sensor holes, 160stat with the ECM programmed to turn on the fan at 170.
italiano67
Dec 11, 2016 09:21 AM
hydrolic144
Oct 4, 2015 08:23 PM
Ducati900ss
Sep 2, 2015 09:05 AM
355tpipickup
Aug 29, 2015 10:47 PM
5spdcamaro
Aug 28, 2015 02:12 AM
