I know that its 1/4" thick but what kind of angle is it? Thanks guys!
Anyone know the angle?
Look in the sticky at the front and there's someone selling these .
i've heard 6-8 degrees... one thread was talkin about 6 and another one was sayin it was 8 degrees drivers side. either 6-8 would work i'm sure.
Quote:
Originally Posted by wanta427
Look in the sticky at the front and there's someone selling these . why buy one when you can make one? Mmm, 3* is a big diff. (to me anyways) when I machine stuff I like to keep a tight spec. down to a thousandth if I can.
where do you go about buying 1/4inch aluminum plates to make a spacer?
yeah keeping tight specs are good but the thickness of the gasket will be enough to make up for the 1-2 degree difference. thats the only reason it needs the slant is to stop oil leaks out of that distributor hole. but like i said, i have heard 6 or 8 degrees. i'd do more research to be sure but i think 6 and the gasket would be enough to keep leaks out
I'll prob use barstock and cut it down to 1/4 and then toss it in the CnC.
91banditt2
close
- Join DateDec 2000
- LocationCincinnati,Ohio
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1991 BandittII Firebird
- Engine5.7 HSR
- Transmission700R4
- Axle/Gears3.27 9 bolt
- Liked:151 Times in 111 Posts
the angle is 5*
i had asked this question to the former owner of www.lt1intake.com and he had told me it was cut at a 5* angle with the high side being 1/4".
4-5*
BTW if anybody needs a spacer PM me. I have a few from making em for a couple conversions.
