Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
External fuel pumps with HSR
Old Apr 22, 2007 | 06:27 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
It looks like I will remove my SR from my stroker motor in order to solve a persistant oil leal on the pass side head. I promised myself if I remove the SR one more time, I would not re-install it, PITA!.
My fuel situation is that I am running Ford 24 #/hr injectors with my 395 cu.in. stroker and the TTA fuel pump. I am going to install 30#/hr injectors if and when I install an HSR. I believe that I am on the verge of running out of fuel now. So,
would an externally mounted fuel pump work well for me?
What brands and model numbers are good?
Old Apr 26, 2007 | 05:38 PM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
Re: External fuel pumps with HSR
I am using a Mallory 110FI with my setup. I am hapy with it.
Old Apr 26, 2007 | 09:13 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Thank you for the response. This board has been very slow lately.
Old Apr 27, 2007 | 06:07 AM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
I used Holley fuel pump the one that comes in the kit. I'm tired of dropping the fuel tank to replac the pump so the external one is nice now. mine os a 255lpm pump.
Old May 1, 2007 | 07:13 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Do you have to remove the one in the tank or
canyou just suck through it
Old May 1, 2007 | 08:27 PM
Blown87's Avatar
Car: 87 Z-28
Axle/Gears: 3:73
My fuel tank is sumped with -8an lines. I would not recommend pulling through the factory pump. The hard line in the tank is only about 1/4" in diameter and not capable of moving enough fuel to make big power. I have been told that external pumps that pull through the factory pump have a high failure rate for this reason.
Old May 2, 2007 | 09:25 PM
Car: 1992 Camaro RS
I removed the pump and added some hose to take up the left over space. I have had no problems to date and it's been over 3 years in the car.
Old May 9, 2007 | 08:16 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Thank you all for the info.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
