Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Fuel Injector to Fuel Rail - How To?
Old May 29, 2007 | 01:29 AM
gstarnes55's Avatar
I have a 1996 v6 3800 Camaro. I have done some repair work that required removing the front injector from each side of the fuel rail. I am having difficulty reinstalling the injector to the rail. I can't seem to push hard enough on the injector AND slide the retaining clip back in place at the same time. Am I doing something wrong? Is there a special technique or some trick to this? Any help or advice would be GREATLY appreciated!!
Thanks, Gary
Old May 29, 2007 | 09:31 AM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Re: Fuel Injector to Fuel Rail - How To?
First off make sure you apply some petroleum jelly to the o-rings because this will allow the injectors to slide in smoothly. I know what you mean about the 3800 clips because i ended up leaving them out because the were a pain to get in. Ive been running it without clips for abut 6 months and no problems.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
