Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Single-Plane Discussion
Old Jul 18, 2007 | 12:40 AM
Kurt04's Avatar
Seems like there hasn't been much, if any, talk about single-plane MPFI on here in awhile. Was it just a phase? Seems like most that don't have single-plane setups think they are useless because the "Don't make more power" (compared to say a MR, HSR, SR) but what they don't realize is its not going to make more power, but rather allow for more power. Or at least thats how I'm seeing it.
So those of you that have already gone to a single-plane or know a good deal about them, I would like to get your opinion on a couple things.
Should I just stick with an Edelbrock Pro-Flo, Holley C950, or Accel Pro-Ram or would it be better to buy a regular manifold and have it converted. I'm almost leaning towards the latter because I could have the injector bungs placed slightly higher to leave room for a Nitrous Fogger bung below it, like this.
If I go with a carb manifold and have it converted what are some characteristic I should look for? I know there are some difference in how a dry manifold acts compared to a wet, but I didn't really get the whole picture.
Throttle body is the next thing I did not seem to find much information on. I know some use a 90* elbow and LS1 or TPI/LT1 style. Or some use 4 barrels right on top of the manifold. Is there any distinct advantage to either setup? I was thinking about a Full Throttle Performance throttle body with the IAC and TPS, like this one. But was unsure is anyone has found any advantage to one setup over the other.
Old Jul 18, 2007 | 12:53 AM
bodie's Avatar
Re: Single-Plane Discussion
there been some post about single plane intakes,
personally i get an intake with the injector bungs already cast into the manifold
like the edelbrock or the new pro products one.
reason being the bung sometime arnt welded in the best angle and not straight.
and that pic above is and example, it ok for the 1/4 but everyday driving will suffer. because the injector are to high causing some fuel to puddle lossing off idle preformance and fuel milage,
that and hes prob using a carb spacer cause the injector rails are to close to throttle body.
here the whole intake
by the look of it he gonna have to run at least a 1.5 spacer for the throttle body
it may not fit under a stock hood
Old Jul 18, 2007 | 01:00 AM
bodie's Avatar
here one with bad injector angle
Old Jul 18, 2007 | 01:38 AM
Kurt04's Avatar
I know there have been some threads on it but as of late, seems only thing anyone talks about in this section is HSP and LT1.
I thought about the puddling issue also, so maybe it would be better to have the foggers above the injectors? Or possibly a plate system.
I'm not worried about fitting under the stock hood, my setup will be in an S-10 with a cowl hood.
I also saw that intake with the almost 90* injector angle and though that was very odd.
Old Jul 19, 2007 | 03:51 AM
Kurt04's Avatar
No one has any suggestions?
Old Jul 19, 2007 | 12:22 PM
bodie's Avatar
yea plate system prob be your best bet, it will give you ore roome to run you injection wiring and be out of the throttle body linkage
Old Jul 20, 2007 | 08:30 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Singleplane is the shiznit. The holley setup I had with the 4bbl throttle body was great. Too bad it didn't fit under the vette hood.
My stance is still:
Miniram is nicer than HSR, but expencive, and has uneven air distribution
LT1 is nicer than HSR, cheap, same issue as MR, and the remote thermostat is fugly
Singleplane is expencive, but makes the most power. (direct airflow).
-- Joe
Old Jul 20, 2007 | 10:26 AM
Kurt04's Avatar
My stance is still:
-- Joe
Yep, I found a complete MR setup for a $1000, I'm really temped to buy it but uneven air distrubution issue is some what keeping me away. Plus, I'd still rather have a Single-Plane because I would like to build for some really high HP later on down the road.
So what is your stance on:
Off-the-Shelf Single-Plane EFI manifold vs. non-EFI Manifold Converted to EFI.
Plate Nitrous vs. Foggers above the injectors (which really could be a topic for the power adder section.)
4-Barrel TB vs. Horizonal (LT1/TPI or LS1 style) TB on a 90* Elbow.
I honestly think I have read just about all the single-plane EFI threads on here, none of these topics are really discussed in full. Anyone know of any other forums out there that may have an abundance of single-plane EFI knowledge?
Old Jul 20, 2007 | 11:55 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
the single plane is going to give you the potential for the most horsepower, due to its larger, short runners, and central-fed plenum.
the decision of purpose build efi manifold vs modifying an existing manifold is going to be strictly cost and skills. If you have a manifold, it MAY be cheaper to mod that one. If you have the skills, the cheapest would be to mod your own manifold and fab fuel rails. the next cheapest would be to buy the purpose built manifold and matching fuel rails. The most expensive would be to have someone build all that for you custom. I don't think you would see much difference in HP if the mods are done properly (NOT like the picture in the above post with bad injector placement).
the throttle question comes down to hood clearance, and cost (again). The TPI type on an elbow has a slighter disadvantage vs a throttle 'plate' and inlet elbow, becuase it will skew the airflow into the plenum, however, this will also provide you a greater plenum volume. The negative is that this might be too tall to fit underhood.
if either situation fits under the hood, you might actually have to try both to see what makes more power(again, you are talking single hp at a time here: maybe worth 15-20hp max effort).
as for the port vs fogger NOS...not being a Nitrous guy, I would think you could still build waaaay more than enough power with a plate to blow the bottom end up that it wouldn't matter.....or i guess worth the extra plumbing hassle. This is BECAUSE the single plane has a nice central plenum.
Old Jul 21, 2007 | 01:08 AM
Kurt04's Avatar
Although I am a machinist by trade, I really won't have access to a shop and/or welding equipment to do my own conversion (next spring after I return from Iraq), so I would have a shop do it for me. I may just go with a purpose built manifold first, eventually put a plate nitrous system on it. Once I'm bored with that I may see about picking up a carb manifold, and doing a conversion with foggers.
I though I had read a couple post in which someone was discussing what makes a manifold better for a dry manifold setup as apposed to a wet manifold setup. Anyone remember this?
The fact that the inlet elbow may skew the airflow didn't even come to mind. That may as well be something I experiment with down the road, but a 4-barrel with an air cleaner on top will most likely be the simpler setup to start out with.
I plan to attend the School of Automotive Machinist in Houston, TX after this deployment, so maybe I can get some flow comparisons between the two setups.
What 4-barrel TB's are everyone using? Anyone using a Full Throttle Performance TB like I mentioned in the first post?
Old Jul 27, 2007 | 01:47 AM
Kurt04's Avatar
So the Edelbrock Performer RPM Pro-Flo, the ACCEL DFI Pro-Ram, and the Holley Multi-Point standalone systems come with MAP, TPS, IAC, and IAT sensors. Does anyone know if these are GM Style? How will they work with a 730 ECU? Is IAT the same as MAT? I know if I piece my own system together to get a throttle body with TPS and IAC, but I guess each of these manifolds have the fittings for the MAP and IAT?
Old Jul 27, 2007 | 07:46 AM
Kurt04's Avatar
Well after some searching, I have found that the Pro-Flo and the Holley have MAP fittings, but on the Pro-Flo the MAT is installed in the air cleaner base (you drill a hole, install a grommet, and stick the sensor through there) which I am not very fond of. On the Holley there is a fitting directly into the manifold for the MAT, from what I can tell. Both seem to be GM connectors as well. I emailed Edelbrock, Accel, and Holley as well as Professional Products (about their Super Hurricane EFI) to get specfics.
Old Jul 27, 2007 | 04:30 PM
brutalform's Avatar
I can speak for the Accel billet 1350 CFM TB. All the sensors are GM style, and will plug right in, except the IAC. All you have to do is get an Accel DFI #77651 adapter, and the IAC will plug in as well. I use the 730 ECM, with a converted Super Victor manifold.
Old Jul 27, 2007 | 07:15 PM
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
I've had my Pro-Ram for over a year now. anesthes is right the mini ram has air distribution issues everytime I changed my plugs or removed the intake, cylinders 5,6,7, and 8 where black with fuel and soot. As soon as I changed to the single plane intake all that went away and I picked up 3 to 4 mph in the 1/4. My best so far is 11.64 @ 119mph with a 1.79 short time. The throttle response is crisper and it take less throttle to cruise. I went to MD last month and got 21 MPG, so I no the tune is on. All I had to do was add some fuel to my VE table. I do all my own tuning and yes on the factory 730 ECM with some help from a LM-1 WB. I just purchased a ZEX perimeter plate nitrous system 3 weeks ago, I tested the system with a 100 shot so far. The WB said all was good. I can't wait to hit the track again. Here are some current pics.
Attached Thumbnails Single-Plane Discussion-nos1.jpg   Single-Plane Discussion-nos3.jpg   Single-Plane Discussion-nos4.jpg
Old Jul 27, 2007 | 11:43 PM
Kurt04's Avatar
Sounds like my setup would be very similar to yours once I get it done.
So did you assemble your own Pro-Ram setup? Cause the only kits they sell are complete with wiring harness and ECU, right?
I emailed Accel but I guess I asked to many questions because their answer was "Please Call."
Holley hasn't replied yet, Edelbrock only told me what I had already known, same goes for Professional Products.
Old Jul 28, 2007 | 08:38 AM
zz17iroc's Avatar
Yes, I pieced mine together seperatly. I bought the intake and rail kit, then I bought the 1200cfm TB. Keep in mind you'll have to buy other items to complete the swap, but it's all worth the money you put in to it. Send me a PM.
Old Jul 28, 2007 | 11:22 PM
Kurt04's Avatar
Well here is the questions I sent out to Accel, Edelbrock, Holley, and Proofessional Products.
Does your SBC *Manifold Name, Part Number* come with fittings for a MAP sensor and have threaded hole for a MAT sensor? If so what size are they? Also what size is the coolant temp sensor fitting? Can this manifold be port matched to a Fel-pro 1206? Or possibly a 1207? What is the throttle body mount flange size? 4150? 4500?
Accel said "Please contact DFI Tech Line @ 248-380-2780" Which I would but I'm in Iraq, but zz17iroc can prolly answer those questions for the Accel setup.
Edelbrock said "The manifold does not have a MAT sensor fitting provision. We pull vacuum from our throttle body to supply the MAP sensor. The driver side is 3/8” NPT, while the passenger side is ½”NPT. It will handle the #1206 & #1207 gaskets without a problem. Thanks."
No reply from Holley.
Professional Products said "NO. You will need to source your own fittings. The manifold has 4-corner water ports are ½”.Fel-pro 1206? Yes. 1207? Yes. 4150. 4500 with adapter."
Old Jul 29, 2007 | 08:35 PM
zz17iroc's Avatar
The Pro-Ram can be ported to 1206 or 1207, you can re-use your current fittings off of your old intake for the (PVC, brakes, Map,) and anything else that require vacuum. The TB also has provisions for vacuum. The manifold coolant temp sensor goes on the front driverside on the intake. The TB is a 1200CFM uint from Accel and it comes with the TPS and IAT sensors installed, all you have to do is set the voltage on the TPS and change the wiring for the IAC so that it works properly. It comes with the flat style connecter and not the square one that's on your current TB. The intake part# is ACC-74139 and TB part# is ACC-74202S4 at summitracing.com. I hope this helps.
Old Jul 30, 2007 | 04:31 AM
Kurt04's Avatar
The Pro-Ram can be port to 1206 or 1207, you can reuse your curuent fittings off of your old intake for the (PVC, brakes, Map,) and anything else that require vacuum. The TB also has provisions for vacuum. The manifold coolant temp sensor goes on the front driverside on the intake. The TB is a 1200CFM uint from Accel and it comes with the TPS and IAT sensors installed, all you have to do is set the voltage on the TPS and change the wiring for the IAC so that it works properly. It comes with the flat style connecter and not the square one that's on your current TB. The intake part# is ACC-74139 and TB part# is ACC-74202S4 at summitracing.com. I hope this helps.
Thanks, I think I have made up my mind now. It was either going to be this or the Holley setup.
I don't have "current intake" though, cause this will be going on my 383 and into my '92 S-10. I'm sure I'll be able to find all the fittings though.
I to will be using a 730, Moates Ostrich, and TunerPro RT and prolly will have S10wildside make me a complete wiring harness.
Old Aug 2, 2007 | 08:37 AM
Kurt04's Avatar
Well Holley finally emailed me back yesterday. This is what they had to say:
TB has vacuum port for MAP sensor. Manifold is drilled and tapped for MAT sensor, 3/8 NPT. 3/8 NPT coolant temp sensor fitting. Fel-pro 1205 only. 4150 Throttle Body flange.
So I think that backs up my decision to go with the Accel Manifold and TB. Just gotta pick the size TB and Injectors.
Old Aug 17, 2007 | 01:42 AM
Kurt04's Avatar
Ok, I'm ready to round up the pieces, but I need to select the TB and injector size.
I know the formula for selecting injector size:
Max HP X 0.5 and then divide that by # of injectors equals lb-hr.
But, I don't really know the HP output, if I had to guess I would say about 450. That would put me at 28lb/hr, is this enough though? Seems like alot of people are using much larger.
What about the TB size?
The complete Pro-Ram comes with 36lb./hr. injectors and a 1200cfm TB, its "rated" at 500+ hp.
Old Aug 17, 2007 | 04:50 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I had the Holley intake, and it can be ported to a 1206... Had a lot of extra material. Maybe I can drum up a picture.
-- Joe
Old Aug 21, 2007 | 03:47 AM
Kurt04's Avatar
Is that formula correct? I just found another that says multiply # of injectors by .80. :dunno:
Old Aug 22, 2007 | 03:31 PM
Phatfiddler's Avatar
-- Joe
I have the Cutler Brand of this manifold. Holley bought out Cutler and resell the manifold setup under their name. But, I am wondering if they made any changes to the thickness around the ports over the years. I need mine ported to a 1206, but it is going to leave about an 1/8" of metal left when done, so it may need some welding to keep it from warping....
I'll get some pics up in a sec of my motor-in-progress. I just got the valve covers and head studs in today, and assembled it for a mock-up.
I think the general consensus is, if you can afford a single-plane, and it fits into your setup, go with a single-plane. But to be honest, I got my entire setup cheaper than what I would have paid for a Miniram, and its not a home-made unit either. If you shop a little, it can be done.
I know it will fit under a stock Camaro hood with some "adjusting" of the under-hood metal support. It will NOT fit under a stock Corvette hood though, and maybe not a stock Firebird hood, so this needs to be planned in the build as well. If you don't mind it, solid motor mounts are a possibility as well to make it fit....
Old Aug 22, 2007 | 03:47 PM
Heres pictures of the mock-up, single-plane, and ports.
Anesthes - how do you like that air intake? Too bad its only in use for the mock-up currently until i get new plumbing......
Attached Thumbnails Single-Plane Discussion-p8220287.jpg   Single-Plane Discussion-p8220288.jpg   Single-Plane Discussion-p8220289.jpg
Old Aug 22, 2007 | 06:55 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Looks familiar. heh
http://members.cisdi.com/~anesthes/singleplane/16.JPG
Old Aug 23, 2007 | 11:00 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
I'd like to jump in on this thread, mostly to just tag along and get some info.
I'm definitely going EFI soon, but haven't decided on an intake. It must fit under my stock IROC hood. I've been researching the miniram and HSR, and now just started looking into a single plane setup. Here's a pic of what I had in mind to possibly fit under the stock hood.
The piece is made by http://www.intakeelbows.com
He also does custom stuff too at a reasonable price.
Old Aug 23, 2007 | 11:26 AM
Kurt04's Avatar
To me that seems like it would be taller than a 4-barrel TB setup. If you look at the first post I mentioned Full Throttle Performance. They make a few very short TB's. With a slim air filter on top I'm sure it would be shorter than most carb setups and would definitely fit under the stock hood.
EDIT: Actually now that I look at the bigger image, it might not be that much taller that the 4-barrel, but as jwscab mentioned an elbow can sometimes skew the airflow in and not deliver an even amount into each chamber.
Old Aug 23, 2007 | 12:00 PM
Car: 1986 Iroc
Engine: Afr 408
I was actually just posting the picture as an example. Thats not exactly what I had in mind. I believe the guy that does those can build something off a cardboard cutout, or a drawing you send him. So I thought I would actually mock something up with the hood and intake on.
Anyway, the design of these "elbows" is critical to get good airflow. I think if you really took your time and worked on the short side radius of the elbow I would think you'd be able to even out the flow. That would be the worse spot for flow I could think off. It can't be any worse than the miniram? With the miniram manifold costing $900 I would think I should be able have a single plane modified and custom elbow made for at least the same price, maybe less.
Old Aug 24, 2007 | 04:44 AM
Kurt04's Avatar
Gotcha!
What is everyones opinion on TB and Injector sizing?
Old Aug 24, 2007 | 01:24 PM
brutalform's Avatar
Kurt, here are a few pics that I told you I would post via our PM conversation. The actual LT1 style IAC at the rear of the TB, and the Accel part # 77651 adapter.
Attached Thumbnails Single-Plane Discussion-picture-007.jpg   Single-Plane Discussion-picture-006.jpg
Old Aug 24, 2007 | 01:30 PM
brutalform's Avatar
Gotcha!
How do you plan on tuning this?
Old Aug 24, 2007 | 01:49 PM
Kurt04's Avatar
'730 and TunerPro RT.
And thanks for the pics and answering my questions.
EDIT: I'm not so much looking for suggestions for might setup, but more like guidelines or a "rule of thumb." Since this isn't meant to be "my" thread.
Old Aug 24, 2007 | 02:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
edelbrock makes the victor manifolds for EFI and they are priced well. I'd like to go single plane and run a 415-434 small block. so i can use 1206 ports and get great airflow for that motor.
a intake elbow that would allow TPI style TB and sensors would be awesome! may not clear stock hood, but a nice cowl hood looks great anyway
Old Aug 24, 2007 | 06:37 PM
brutalform's Avatar
This all fits under a "cowl" hood. Its a 2.5" air cleaner, and a 1" spacer under the TB. The reason I had to use a spacer was because the throttle linkage would hit the fuel rail standoffs. This is a Super Victor, and Intake Elbows did the injector bung work. I highly recommend them.
Old Aug 24, 2007 | 08:29 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I converted a Vic Jr over to EFI and have it sittiing on a shelf. I actually plan to use it on a LT1 motor now. Reason being is Im going with a Turbo setup and dont want to worry about distribution problems known with the lt1 and miniram intakes.
Im actually in the middle of making a 90* elbow and have a LS1 TB Im gonna be using. (will have pic's of elbow once My wife gets back from FLA)
Old Aug 25, 2007 | 06:38 AM
bnoble's Avatar
Car: '91 Firebird Formula
Engine: 383 w/ BW S400 turbo
Transmission: TH400
Axle/Gears: QP 9", 35 spline, spool, 3.15:1
Do you have any worries about front-to-back air distribution with the elbow? I'm surprised, in all the examples that I've seen, that no one is using turning vanes in the elbow to even out the airflow. Maybe the large common plenum area in a single plane intake is enough to even things out?
Old Aug 25, 2007 | 09:03 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Ive never really heard of anyone having problems.
I cant see an Elbow with a LS1 style TB being any worse then a 4bbl style throttle body with a bonnet on top.
Old Aug 25, 2007 | 04:25 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Here is a link to these people that do some SERIOUS manifolds! Better have REALLY deep pockets to afford one!
http://www.hogansracingmanifolds.com/
Old Sep 4, 2007 | 12:09 AM
Kurt04's Avatar
I found a new single-plane intake and 4-barrel throttle body. (Well I dunno how new it is but I know it hasn't been mentioned in this thread.)
Its made by FAST. http://www.fuelairspark.com/Products...folds/over.asp
On ebay you can actually buy the intake, fuel rails, injectors, and throttle body together.
Honestly the throttle body looks a little "cheap" to me. Which is odd, I've always thought FAST made quality stuff, I know alot of LS1 guys like their intakes.
I think I'll stick with my plan to put together a Pro-Ram setup. I'm ready to buy my intake and throttle body so that I can have them shipped to S10Wildside (EFI Connection) so that they can confirm the IAC connector and the proper wire lengths need for my custom harness.
Brutalform's TB has the LT1 style IAC, but on Accel's website the one in the pics looks like it has TPI style IAC. (Thats the 1350 cfm) And of course, Accel has not responded to my emails.
Summit, Jegs, and Scoggin-Dickey all carry the TB and intake. Summit's TB are on backorder about a month. Jegs about 2 weeks. SD's site doesn't say their TB's are on back order, but they want $73 more for the intake!!! So I'm waiting on a reply from SD, to see if they are instock and if they will price match Summit on the intake. Prolly won't, but its worth a try.
Old Sep 5, 2007 | 05:58 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
On my fried Fredrik's BBC trubo IROC we made an elbow that cleard the stock hood. That was with an air-gap single plane. The trick was to go to the side instad of forward.
I agree that a larger radius would have been better, but then it would not have cleard the hood.
A 4bbl tb would never have cleard the hood.
Personally think this 'carb hat' looks like it has the roof to close to the ports.
Old Sep 5, 2007 | 08:45 AM
  #42
Car: 1986 Iroc
Engine: Afr 408
That is a pretty wild setup. If you were able to cram all that under the stock hood, that gives me a little more confidence.
I think I'm going to try to tackle a single plane setup this winter. I plan on using a Victor Jr. intake, a Wilson manifolds elbow, and their LS1 style throttle body.
I'm expecting to have to mill the elbow and the manifold some to get it to fit, and then probably send it out to get ported and modified for fuel injectors.
Old Sep 5, 2007 | 01:28 PM
  #43
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Proof:
Old Sep 5, 2007 | 01:48 PM
  #44
That Turbonetics 'carb hat' was designed to take boost Its also the same height as my standard 3" air cleaner.
Last edited by Phatfiddler; Sep 5, 2007 at 01:52 PM. Reason: Automerged Doublepost
Old Sep 7, 2007 | 12:19 AM
  #45
Kurt04's Avatar
Decided to go with the 1,200cfm instead. Mike said they just arrived yesterday.
Old Sep 8, 2007 | 09:37 PM
  #46
S10Wildside's Avatar
I didn't expect to see a pigtail coming off of the TPS sensor. Can anyone confirm that the 730 harness TPS connector will be pinned properly for this TPS?
The throttle body looks great!
Old Sep 9, 2007 | 12:22 AM
  #47
Kurt04's Avatar
Hmm, I wasn't expecting that either.
But I don't know if his TPS has a pigtail or not.
Did you figure out the IAC? Which style connector did it have?
Old Sep 9, 2007 | 06:08 AM
  #48
The TPS has an adjustment, but it's not a GM TPS. The IAC is LT1/LS1 style.
Old Sep 12, 2007 | 08:27 PM
  #49
zz17iroc's Avatar
S10Wildside is correct.
Go to your local Junkyard and cut off an IAC connector from a 89 to 92 Berreta, Caviler, or Sunfire those cars use the same style connector as the 1200 CFM TB. Make sure you leave yourself at least a 8" pigtail on the connector. There is no need to modify the TPS connector, it plugs straight in.
Old Sep 13, 2007 | 03:44 PM
  #50
...or visit http://www.eficonnection.com. We stock new connector pigtails.
