Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Edelbrock Pro-Flo XT?
Old Jan 12, 2008 | 09:36 AM
Guss_B's Avatar
Car: '84 Z28 & '73 camaro LT
Engine: 1960 283, eaton m112 blower
Transmission: none at present, will be manual
Axle/Gears: 3.73:1 lsd
Does anyone know anything about the new edelbrock pro-flow XT tunnel ram-esque intake? I just saw it in their new for '08 catalogue (it induced a semi if I'm brutally honest) but it's the first I've heard of it
Old Jan 25, 2008 | 06:49 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Edelbrock Pro-Flo XT?
first i've seen it and it looks good
basically another stealth ram like manifold building power in th 1500-6500 rpm range
http://www.edelbrock.com/automotive_...e/npb_2008.pdf
catalog in there
seems to be for vortec/e-tec heads or pre 86 sbc heads at the moment... but you can drill the bolt holes for 87up style i'm sure
Old Jan 25, 2008 | 08:54 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I like you can use LSx style throttle bodies.
And I like they put it out so quick without having to hype it up so much *cough bbk*
Old Jan 25, 2008 | 09:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
ls1 tb is nice but looks like that unit will not beable to swap onto our cars without the wiring harness/ecm kit that edelbrock uses. Thats probly gonna run the package upwards of 2000 dollars or more which aint bad but not always a great choice when you can tune the stealth ram for less using stock ECMs
Atleast its better looking than those other MPFI setups that look like carb setups. my next EFI (not the one i'm doing now) engine may be using a converted victor single plane.
Old Jan 29, 2008 | 05:20 PM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
I like how it seems to have a lower profile than the stealthram.. some firebird/corvette guys will like that :P
oh my bad
I thought it was the red intake on the first page of the pdf file
Old Jan 29, 2008 | 08:24 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
This thing available for sale yet? Pricing?
I'd swap my miniram out for one. Monoblade TB is where it's at.
-- Joe
Old Jan 30, 2008 | 12:23 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
doesnt look like the throttle body would be much fun attaching a tv cable to...let along getting the proper geometry.
Old Feb 15, 2008 | 04:17 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
-- Joe
I wouldn't mind doing it just for the ease of getting a huge cheap stock TB and the round piping for cold air or forced induction setups.
Old Mar 13, 2008 | 06:01 PM
redcorvette's Avatar
Car: 85 vette
Engine: 427 SHP block,AFR 210,MiniRam
Transmission: TKO 600
Axle/Gears: 3:07
Just got off the phone with Edelbrock. The suggested retail is $3748.95, and it is 9 1/2 inches high.
Old Mar 14, 2008 | 01:25 AM
Pocket's Avatar
Car: 91 Trans Am
For the whole deal including aftermarket EFI
How much for just the intake and rails
Old Mar 14, 2008 | 10:33 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
That is interesting. I'd like to know flow #s on it. 9.5" tall... I'll have to measure my HSR this weekend so I can have a comparision in my head. If it flows more than the HSR, and it has an adaptable LSx style TB to our throttle cables etc, that would be a very intreguing setup.
Old Apr 2, 2008 | 04:49 PM
sol_searcher's Avatar
Talked with Edelbrock guy at the Good Guys event in OC two weeks ago and he said the system was still being tested and that none had shipped.
Old Apr 3, 2008 | 08:31 PM
BackInBlack86's Avatar
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
with a $3700 price tag, i'd be more tempted to use this for $2000 less...
http://www.tpiparts.net/inc/sdetail/3128
not sure about wiring but for saving $2K right off the top, i'll deal with some wiring issues.
Old Apr 4, 2008 | 08:38 AM
Be careful about that "$1700 less"....
The Edelbrock package is a COMPLETE EFI conversion. It includes a distributor, wiring, ECM, injectors, pump, and some other goodies, that that RamJet setup doesn't. Of course not everybody needs all of that; but that comparison is not apples to apples.
It'll be interesting to see what they'll charge for just the intake casting, and whatever it takes to install it, like fuel rails; if it's competitive with the HSR for example.
Old Apr 5, 2008 | 08:15 AM
Guss_B's Avatar
It seems to be like Edelbrock are gonna want to make the price point of the manifold alone competitive so they can pinch some of Holleys stealth ram customers
Old Apr 15, 2008 | 03:55 PM
Just got off the phone with the Edelbrock tech (?) line with questions about the XT.
Said the XT won’t ship till next month.
Said it will only support 450 to 500 horsepower. It will certainly support my horsepower goals but still seems rather limited.
I asked if it was sequential fire and the tech said it was batch fire. I pointed out that on
http://www.edelbrock.com/automotive_new/mc/efi/pf-xt_intro.shtml
it said it was sequential. Tech then said it was sequential.
I asked how he would compare it to a ramjet and was told “ aftermarket is always better.” What a joke.
The system only has one narrowband O2 sensor. I asked him about tuning with only one sensor on a dual exhaust car. He said, “you only need one sensor and that you don’t need to know what the other cylinder bank is doing.” If that is true then it seems to me like their new ECM must be rather simplistic. Don’t you need to know what both cylinder banks are doing to tune better? If not why does my LT-4 have two O2 sensors?
He also said no pricing was available. I told him I had seen it priced.
http://www.truckaddons.com/Catalog/subpages/EdelbrockFuelInjection_1.asp
So what are your opinions thus far on this system?
http://www.edelbrock.com/automotive_...xt_intro.shtml
Old Apr 15, 2008 | 08:18 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Well when they give out the part number for just the intake and rails, color me interested.
Old Apr 29, 2008 | 09:36 AM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
There you go.
http://www.edelbrock.com/automotive_...xt_chevy.shtml
Intake alone runs about $400-$450 then add LSx tb and fuel rails
Old Apr 29, 2008 | 01:09 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally Posted by shaggy56
There you go.
Wonder how much fuel rails and and FPR run..
Wonder what the height specs are too.
I'd def sell my miniram and 58MM throttle body and buy one.
-- Joe
Old May 6, 2008 | 05:23 PM
KENS80V's Avatar
Car: 1980 Corvette
Engine: 383 fuel injected
Axle/Gears: 3:07
Prices are listed at Jegs and Summit now. Should be available by end of May. Low $400s for manifold and $130 for fuel rails.
Old May 6, 2008 | 05:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
HSR price range..not bad..its nice to see another option available
So how do you adapt a LSx tb to our TPI style electronics and cables?
that be a nice setup for a 411 lsx pcm swap, the obd-II conversion plus LSx tb's come in 78 to 105mm so that will cover all your hp goals
Old May 7, 2008 | 05:37 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I think the best part about thise is that unless you want to run a stock or modified TPI throttlebody on a HSR, you have to get a performance TB like a bbk.
If you ran this PFXT you could get a nice stock TB from an LSx even from a truck to use. Just cable bracket (like the one they have for this PFXT) and harness adapters for the IAC and TPS would be an issue.
If you call Howell Engine Developments Bill Howell will make them for you probably cheap too, or you could just change your cable ends with the new weatherpack (which Bill Howell can get too).
Old May 7, 2008 | 05:59 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
LS1 is almost direct fit. I ran both an LS1 and a vortec TB on my single plane intake back in 2004. Other than changing the plugs for the TPS and I think IAC, the signals and voltage is all the same.
I'm kinda psyched about this intake. I wonder how tall it is though. If it's as high as a HSR it won't fit in a Corvette.
-- Joe
Old May 7, 2008 | 06:51 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
That's a very close fit for the waterneck, nice looking piece though, regardless....
Old May 7, 2008 | 09:48 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
if its just a matter of getting LS1 style connectors and sensors and splicing into the stock TPI harness, thats a sweet deal! I have no problem doin that
Old May 7, 2008 | 08:39 PM
kanexpl's Avatar
Car: 94 C1500
Engine: 353 TBI
Axle/Gears: 4.10
Do you think the manifold has enough plenum volume to feed the runners? How long are the runners? They look about 8 inches long. It looks like it would push the power band to 6000 to 6500 range. I have only seen the right side in the pictures. Does the left side have brackets for the throttle cables. Would you have to run a tpi throttle cable. I don't think the cable would be long enough if it crosses over to the left side. I guess you could use a tac module from a vette and electronic throttle body.
Old May 11, 2008 | 08:02 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Actually they make adaptor harnesses already made up or as said you can splice.
Old May 11, 2008 | 08:25 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
It appears to have more plenum and more runner than the TPIS miniram or singleplane, so I would say yes, it is enough.
Old May 26, 2008 | 10:21 AM
9secz28's Avatar
Car: 1987 Camaro
Engine: 383ci
Transmission: th350
I wonder if it has enough metal around the ports to be port matched to a 1206 gasket. If so, that's the intake i'll be running!
Old May 26, 2008 | 01:33 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
also from the pic, it looks to be alittle taller than miniram but much shorter than HSR
Runner lenghts do appear to be longer than miniram and near similar to HSR. This intake should match HSR in performance and support up to 6500rpms on some motors
Old May 27, 2008 | 11:21 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
"I'd def sell my miniram and 58MM throttle body and buy one. "
-- Joe[/QUOTE]
I've been running a MR for the last 7 years. Over the winter I installed a new solid roller cam in my 406. Without a doubt, the combo of good cam, heads and MiniRam is an outstanding combination!
I wouldn't trade it for any other intake on the market.
One man's opinion.
Old Jun 8, 2008 | 11:06 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Looks like a great intake for the price and if shorter then the HSR would fit nice in any TA or corvette, they should sell a lot of them. Kind of wonder why they didn't make it for 87+ also as well? If I ever build up a stronger block that can take some rev's I'll probably get one myself
Old Jul 17, 2008 | 01:42 AM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
I too have been very interested in this intake. Looks like it would be great on our cars, and the LSx throttle body is a win win! I dont know about anyone else, but I have a mini ram currently on my car and for the past three months I have been trying to figure out an intake pop and loss of power. After breaking down and paying 500+ dollars at a local shop to have it looked at, it appears the mini ram did not mate with the heads and was causing a major vacuum leak. I have heard others horror stories as well with this problem, and I am disgusted that I paid over 1400$ for my intake and it is a worthless piece of crap! I will definately be contacting TPIS about this, and After seriously considering carbed (I know I shouldn't have even thought about it) I will probably be getting the edelbrock set up. If anyone finds anything new about it, or what it takes to get it to work on a TPI motor, post it up. I'm very interested to hear about it.
Old Jul 20, 2008 | 01:37 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
I am pretty interested as well.. Seems a little too cheap to be true, Though. Does anybody know what it would take to get it to fit on an 87-up motor?
Old Jul 20, 2008 | 03:37 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
just gotta angle the bolt holes. use a dremel tool and cut them open so the bolts line up. then you can either use JBweld or quiksteel epoxy putty to fill the excess or leave as is and use a washer under the bolt to take up any slack
Stealth ram intakes are drilled like that, for both style heads. So all you need to do is modify the bolt hole angle for that pro flo to fit
AND to add, there is a company that makes a cut down HSR for C4 vettes that will work nicely for our cars as well if you have Irocz hood and poly motor mounts, as it doesnt clear 100% or if you have a TA/firebird etc. its 850 bucks and has the center section cutout more like an airgap manifold. Its pretty
I think that intake will support 6000 rpms and 11 second time slips. My HSR is doing very well on my 383 so far so i'd expect similar performance out of that ProFlo once on the right combination
Old Jul 21, 2008 | 10:21 PM
850 sounds good.... Do you remember which company makes the cut-down version? As long as it dosent interfere with a 2" cowl induction hood, I'm interested!!! Thanks!!
Old Aug 29, 2008 | 10:08 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Anyone here running one of these yet?
Im looking at getting into the EFI game and this seems like a decent unit (sequential, complete kit and good price)
Old Sep 1, 2008 | 11:08 PM
pearlphoenix's Avatar
Car: 86 Trans Am
Engine: 383
Transmission: Probuilt 700r4
Axle/Gears: 2.77 BW 9 Bolt
yeah id really like to know if anyone is running this as well, and if the tps and iac is just a matter of splicing a few wires with new connectors
Old Sep 2, 2008 | 12:09 AM
1bdbrd's Avatar
Car: 1991 Trans Am
I am planning to get one soon. I already have the money set back and the 90mm throttle body. Last time I checked Summit Racing's website the intake and rails wouldn't be available until September 14th. It just got pushed back as it used to say August 30th. Hopefully it will be availabe soon.
Old Sep 11, 2008 | 12:50 AM
RedGut86's Avatar
Car: 86 Corvette 383
Engine: 383 LPE build
Transmission: 4+3... T56 soon enough
Axle/Gears: 3.07
Just thought I'd post up here, there a thread with some new info over on CorvetteForum.
http://forums.corvetteforum.com/show....php?t=2127378
Old Apr 20, 2009 | 05:01 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
so has anyone tried this one im really intrested since i need to dump my 305. was wondering if that cable issue has been solved or not more for the tv cable. really intrested to see whos tried it and all.
Old Jul 19, 2009 | 05:37 PM
  #42
carguy502's Avatar
Car: 1969 Nova
Engine: LT4 Hot Cam L98
Axle/Gears: 3.42 8.5" 10 bolt
This might seem like a foolish observation, but does it even look like a small cap distributor will fit back there. The XT kit uses a small diameter mallory distributor.
Old Aug 7, 2009 | 08:33 PM
  #43
Low_Yukon's Avatar
Car: 92 GMC sierra 4x4
Engine: 97 355 Vortec
what would you have to do to run this on a tbi engine?
Old Aug 8, 2009 | 12:43 AM
  #44
RedGut86's Avatar
Axle/Gears: 3.07
FYI, I was told this should support 600hp and you need a 90* waterneck to make it fit with the 90mm TB that expands to over 4 inches in diameter as it goes out. What is 90mm good for though? Probably overkill for most. No?
Also, Corvette and I believe the Formula's are going to have problems with the hood, but as soon as I have funds I think I have a solution. Some guy on CF has made an adapter to get an LS1 TB to work, I'm gonna give it a try with another angle... once I get some funds...
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
