Quick help, fuel injectors for miniram
Car: 85 vette/87 TA
Engine: built 383/350 tpi
Transmission: built 700r4s
Axle/Gears: 3.45 dana 44/ 3.27 9 bolt
My accel 30s, just 2 years old, went bad on my minirammed vette.
The guy I bought the injectors from, Jon at fuelinjectorconnection.com, asked me what size o-ring I need for the top of the injector, 14.5mm or 15mm.
I don't have the car with me, and really need to get this figured out, any ideas?
He did mention that gm rails use 15mm, aftermarket use 14.5, and since I have tpis fuel rails, I'll assume 14.5, but just want to make sure.
Thanks Guys!
Thanks Guys!
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: Quick help, fuel injectors for miniram
I was under the impression that GM is 15.0mm, while Ford is a bit smaller (14.5mm). If the aftermarket piece is meant to replace a GM part, then the oring OD should be 15.0mm. I am running Ford Racing 24s in my 395 cu.in. stroker. I did not swap out the orings. No issues with fuel leaks for 10 years.
Car: 85 vette/87 TA
You are right doc. Gm uses 15, ford uses 14.5. However, aftermarket fuel rails for gm utilize 14.5 also. I believe you still use the stock fuel rails with the super ram.
Tpis sells fuel rails with their miniram, they aren't gm rails, thats why I asked. I guess I'll find out when I put them in.
Car: '87 IROCZ
Engine: 395 ZZ4
When you are finished with your install, check for fuel leaks by simply turning the key to the ON position and energize the fuel pump. Do not start the engine. Check for leaks. Be safe and careful.
Car: 85 vette/87 TA
Just thought I'd give an update. The injectors required the 14.5mm ring for installation in the miniram. Everything is going pretty well now.
LT1Formula
20
Nov 14, 2015 12:02 AM
Firechicken86
Aug 12, 2015 10:07 PM
