Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR distributor selection
Old Apr 14, 2009 | 08:09 PM
TheJuggla's Avatar
Car: My olds 88, but soon my camaro (Not in Winter)
Engine: 305 swapping to 383
Transmission: not sure as of yet, putting in 700R4 soon
Hey guys, building a 383 stroker with a HSR intake in my 89 camaro. I have heard that there are clearance issues with the stock distributors and was wondering if this would be a good replacement (summit pt# MSD-8489). Just wondering if i could get some opinions on this. Thanks
Old Apr 16, 2009 | 10:11 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Re: HSR distributor selection
I've got the MSD 8366 for mine.
Old Apr 17, 2009 | 02:43 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The MSD you mention might fit , but I doubt it would have much adjustment . 2nd it requires a crank trigger .3rd it doesn't appear to a computer controlled dist which means it won't work with the stock electronics.
Any remote coil small cap dist to suit a 3rd Gen will fit. As it is there is only 1/4" clearance cap to plenum with small cap dist
Old Apr 17, 2009 | 05:11 AM
TheJuggla's Avatar
ok, so basically i should just stick with a regular dist. cause i do want the computer control and dont want to deal with a new trigger style. The MSD 8366 definatly looks nice, but im not quite sure what the jacks are for. Are they for an ignition box or hook up to a laptop? And would an ignition box be a good idea to add to the project?
Old Apr 18, 2009 | 10:01 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
They duplicate the orginal F-body dist plugs.
The 4 wire is for hookup to the computer for spark control and the 2 wire is the coil connection
If your Camaro has a small cap dist then the MSD would plug straight in.
If you have a HEI there is a $15 adapter harness and remote coil needed
Old Jun 11, 2009 | 04:42 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am running the 8366 as well. it is computer controlled.
Old Jun 23, 2009 | 10:38 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
i ended up just using a stock distributor from a 87-up and modifying the wiring.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Damon
Sep 26, 2015 04:29 PM
