Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
runners / cam
Old Jul 3, 2009 | 10:23 AM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
runners / cam
Im running an 87 GTA TPI 350 auto, I noticed at the track that when I reach 4500 rpm im not pulling as hard.
Is this due to the long runners or is it because of the cam?
With a set of better runners would I be able to pull hard till 5000 rpm or higher on this stock cam?
Old Jul 3, 2009 | 11:20 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Re: runners / cam
The stock cam isnt exactly great, but this is 99% the fault of the 17in of runner that the air has to traverse before it reaches the chamber.
A runner upgrade may help, but be advised that unless you get a siamesed set, the actual length of the runners will not change. You may be able to pull some higher r's with a better base and runners. But with the cost of this kind of upgrade, I would seriously consider putting the money towards an HSR or Miniram.
Jorlain
Oct 8, 2015 01:57 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
toronto formula
Sep 10, 2015 07:31 AM
hydrolic144
Sep 8, 2015 06:59 PM
89fast5oh
Sep 8, 2015 09:55 AM
