Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Injectors for Holley Stealthram
Old Dec 15, 2009 | 02:55 PM
jeaux's Avatar
Car: 85 Camaro Z28
I would like to know what brand injectors everyone is using with their HSR, and if any modifications were needed. I was told that the only injectors that will drop in without modification are the Holley's. Truth or BS?? before I spend my money. Thanks!
Old Dec 16, 2009 | 02:08 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Re: Injectors for Holley Stealthram
I use Ford Racing.0 Accel, some Bosh also will fit - no modifications if used with Hollay Fuel Rail dedicated to HSR
best regards
Old Dec 16, 2009 | 12:50 PM
Beater79TA's Avatar
I got mine for fuelinjectorconnection.com. They were familiar with the intake and could set up the lb/hr size I needed with no issues.
I've also used stock injectors in the same HSR with no fitment issues so anything that fits a TPI should work with your HSR.
Old Dec 18, 2009 | 08:06 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I have Ford Racing injectors also, 30#/hr.
Old Dec 18, 2009 | 08:55 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
holley does not make injectors.. they just rebox.. call jon at fuel injector connection he will save you a bunch.. he knows the manifold set up
Old Jan 19, 2010 | 11:00 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
The stock HSR rail kit is way over priced and very limited
I built my own fast fuel rails and installed Delphi 50# set to 44# 36PSI
Delphi is the manufacture all vendors purchase from
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
