Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
remote coil wiring
Old May 26, 2010 | 11:58 AM
Billd's Avatar
remote coil wiring
Im putting an hsr on my 86 with the coil in cap dist. I bough a new small cap dist and oem remote coil. I have acess to the plug ins for it and it looks like the 4 prong and 2 prong connectors to the distibutor will be just cut and splice the wires to the other pigtails. but what about the wires that ran from the old distributor to the coil in the cap. i have to wires on the firewall that i assume are coil + and tach wires but the new coil has 2 more terminals so where do i run those to?
Old May 27, 2010 | 12:17 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: remote coil wiring
Originally Posted by Billd
what about the wires that ran from the old distributor to the coil in the cap. i assume are coil + and tach wires but the new coil has 2 more terminals so where do i run those to?
The late GM coil with dual connectors has a in and a out side
So you have 12V power (pink ) and tacho - ( white ) to coil on one side and the pink +and white - wires from coil to small dist plug on the other.
http://www.trifive.com/forums/showthread.php?t=11500
stalkier
Dec 6, 2015 11:25 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
L98GTA87
Aug 5, 2015 11:02 PM
