Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
needs some help!
Old Aug 6, 2010 | 07:18 PM
lkefthrlkeson's Avatar
needs some help!
I'm planning on building a 355 with vortec heads & a first tpi system. Gonna keep the compression around 9:1 for pump gas. Can't decide what cam to go with. Want to have at least 350hp, would be happier closer to 400hp, but I don't want to sacrifice driveability and gas mileage. Any help would be appreciated. Thanks guys
Old Aug 7, 2010 | 04:05 PM
redcorvette's Avatar
Car: 85 vette
Engine: 427 SHP block,AFR 210,MiniRam
Transmission: TKO 600
Axle/Gears: 3:07
Re: needs some help!
As a start you could look at https://www.thirdgen.org/forums/engi...st-builds.html
post #5, just keep in mind the results are with ported vortecs and they have been modified to allow extra lift. I believe stock vortecs are limited to .450 lift.
Some info on porting https://www.thirdgen.org/forums/engi...sbc-heads.html
If you have a pre 87 block going to a roller camshaft will add about $500 to your costs.
If you do enough searching on this site you should get a good idea of what you want to do.
