Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Stealth Ram Intake
Old Nov 5, 2010 | 06:18 PM
SuperRamFormula's Avatar
Car: 87 Formula 350,11.65@122
Engine: 383,AFR Comp 195,XFI280,SRam/Mram
Transmission: T-56 Magnum-F
Axle/Gears: DANA 44 with 3.92
Stealth Ram Intake
I'm trying to find out some real world info on this intake. I'm currently running a SuperRam intake system, upper, lower and 58mm throttle body on a 383. I'm also using the cam designed for this intake, 219/560 using 1.6 rockers. AFR 190 heads and SLP 1 3/4 headers, thru a Flomaster 3" exhaust. My 87 Formula is making at the wheels 335 hp @ 5200 and 420 ft tq @ 3500. I'm making 380 ft tq @ 4200. I'm running 12.3-12.5 @109-110 mph. when I can get my Nitto's to stick. I figure the Stealth Ram would give me some more upper end power. Just don't want to loose to much at the bottom. I would like to hear from some people using this intake and what they think of it.
Thanks,
Tom
Old Nov 5, 2010 | 06:26 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Re: Stealth Ram Intake
Check out the Alternative Port Intake thread. Tons of info there. Also try the search button. The Stealth Ram will kill some bottom end power, but it will make up for it on the top end. By any chance is that cam the Lingenfelter 219 cam?
Old Nov 5, 2010 | 06:41 PM
Yes, it is the Lingenfelter 219.
Old Nov 5, 2010 | 11:30 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
personally man.. i love my stealthram i cant say i noticed any loss on bottom end.. but i went from a tbi to a carb on a basically stock 350 to what i have in my signature with the stealthram..
Old Nov 6, 2010 | 01:16 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
383 with heads/ cam comparison
Torque curves are very similar;HSR has less than 10ft/lb difference over a SR but 500 rpm further up
Old Nov 6, 2010 | 10:06 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
How do you like the current setup? I am about to go 383 and have similar mods. Let me know! Anything done to the trans or rear? Stall?
Stangski09
Nov 14, 2015 01:27 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
R3500
Sep 8, 2015 10:12 PM
09ave
Sep 7, 2015 06:03 PM
