Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
single plane efi intake
Old Jun 29, 2011 | 02:19 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Hey gang, I would like to get a victor jr style intake that is efi so I could keep my factory 92 speed density system. I would also like to get a functional cowl hood and air cleaner and make it work like an old chevelle or 69 Z cowl hood with the flapper. If anyone knows what throttle body and intake will be compatible with my harness and throttle cable please let me know. I still have the flapper assembly from a 69 Z I had back in the 80s but I will need a hood with an air box to seal against the air cleaner.
Old Jul 1, 2011 | 04:53 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Re: single plane efi intake
I have the Victor Jr EFI with a Edelbrock 1000cfm throttle body. Everything was pretty much plug and play. Depending on which throttle body you go with, you may need to change your TPS harness plug and IAC harness plug. EFI Connection has what you need.
Old Jul 2, 2011 | 08:13 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
My Accufab TB uses late model LT1 TPS and IAC
Old Jul 3, 2011 | 03:54 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
How does your guy's cars run after the swap? I've been comtemplating to this for my 91 L98 car. Any major torque loss?
Old Jul 4, 2011 | 05:55 PM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
My car is a 406 with a solid roller. Torque is not a problem. On a relatively stock motor, I probably wouldn't recommend it. If you build the motor with an aggressive ramp cam and a good set of heads, the intake will help you make very good power.
Bubbajones_ya
Jul 6, 2024 08:32 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
ericjon262
Sep 11, 2015 06:07 PM
toronto formula
Sep 10, 2015 07:31 AM
