Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
stock fuel pump how much hp
Old Jan 26, 2012 | 07:03 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
I looked in search button didn't see it so
How much HP u think a stock rated FP can hold its for my build I didn't get much as I thought :-( so plan B a 305 LB9 build up shooting for 300hp with stock bottom end with arp bolts if I can get a mini ram used or anything better than the stock tune port. I will work the heads over if I have enough I will put skrew in rocker studs.
Any who its not the O.E. 1 that came with the car its newer bout 5k or more from autozone
Old Jan 27, 2012 | 11:16 AM
Ronny's Avatar
Re: stock fuel pump how much hp
stock TPI pump I read flows 24 gal/hr or 91 liters/hour of gas.
That calcs out to 500 HP. So I would say 400-500HP.
Old Jan 27, 2012 | 05:28 PM
Sojer's Avatar
Thas great
Old Jan 27, 2012 | 06:27 PM
383RAT's Avatar
Car: 1988 Firebird Formula 350
Engine: L98 383 cubes Multipoint FI
Axle/Gears: Ford 9 inch with 3.70 gears
I had the stock fuel pump with 30lb injectors @ 50 psi on a 383 and i was able to make 376 HP with only a 1psi drop at wide open throttle so I'm sure you will be fine with a stock fuel pump for what you are doing.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
