Anyone want to post pics of HSR setup, passenger side?
Guest
Posts: n/a
Hey guys,
I've just got every last bit of my TPI off. I will be installing an HSR on an all stock L98, minus full exhaust. I'm staring at all of the tubes and connections in the center of my engine that I disconnected to remove the TPI manifold and I'm pretty confident I can put everything back the way it was, minus EGR. Buuuuuttttt....just in case, anyone care to post a picture of their assembled HSR setups, preferably on a stock motor or one that has all stock hook ups, and preferably of the passenger side as that is where most of the connections and tubes are. Thanks in advance guys.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Anyone want to post pics of HSR setup, passenger side?
The hoses that came off your stock TB go back where they came from ;
the large hose to rocker cover and the smaller vac line to the purge canister ( assume you have the TB bypass done )
The vac lines that came of the pass rear of the TPI plenum are relocated to the rear of the HSR as does the
vac line to the brake booster
Some also relocate the TPI MAT sensor to the rear so they can use the hole under the HSR plenum for the
PCV line from the drv side rocker cover as shown below
