Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Fuel pump choices
Old Feb 26, 2013 | 04:22 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Fuel pump choices
What is the best fuel pump to use with the hsr can i use the stock in tank pump or do i need something that would be more pressure to hold up the 32 lbs venom injectors i have the stock ac delco pump now for the l98 350 tpi
Old Feb 26, 2013 | 10:00 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Fuel pump choices
Why do you need 32lb injectors on a 355 with only Vortec heads?
Guys are running 383's with 24 lb injectors
Old Feb 27, 2013 | 02:51 AM
Nelz's Avatar
If you are making over 300 HP at 43.5psi you will have your injectors lock out, and burn a hole in your piston due to a lean running condition.
http://www.rceng.com/technical.aspx
30lbs. are good to about 380HP.
You can stretch it a little bit by bumping up fuel pressure to 50psi.
I used racetronix's kit.
http://www.racetronix.biz/customkiti...c=RFPK-005&eq=
Comes with Walbro 255LPH high-performance fuel pump
Old Feb 27, 2013 | 06:04 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
30 lbs injectors are good for 450 horsepower on a BSFC of around .5
A duty cycle of 80% is imaginary. The injectors don't have any idea what the duty cycle is, since they have no idea what the firing window is. To say that an injector is unhappy being open "90 percent of the widow of time" vs "80 percent" is just plain silly.
It's just a solenoid.
On the other hand, injectors do become erratic if you try to command them to fire for a window of time that is too short. There is a certain amount of time it takes for the injector to open, and the injector to close. Some injectors can't be fired sub 1ms, so if you over inject a car you might find your idle to be very erratic while at WOT you're only at 80%.
-- Joe
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
