thoughts on this single plane efi setup
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
I have a l31 vortec with a holley tbi with gm injector pod on a edelbrock rpm air gap intake the motor is all stock other then bolt ons and runs mid 13's now I want a little more and a better fuel system so I built a all forged l31 with a mild comp cams cam http://www.jegs.com/i/Comp-Cams/249/...81#moreDetails
I was thinking of using this intake http://www.racingheadservice.com/rhs...ons-10130.html
and my tbi base with a block off plate and buying the ebl flash and port mod do you see and problems that I maybe over looking in this set up working well?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: thoughts on this single plane efi setup
-- Joe
Engine: forged 350
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
That plus $100 fuel rails. Under $300
I'm running the SBC version of that gasket matched to my AFR-210 heads.
I'm running a megasquirt though rather than an EBL.
-- Joe
Engine: forged 350
Professional Products Hurricane Plus Intake Manifold SBC Chevrolet Vortec | eBay
-- Joe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I have an elbow and a 95mm throttle body, but you get the idea:
https://www.thirdgen.org/forums/atta...r_finished.jpg
-- Joe
Engine: forged 350
I linked the wrong one. The EFI version is like $180.
-- Joe
-- Joe
Engine: forged 350
-- Joe
-- Joe
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I dont understand how that thing can fit standard and vortec ports properly. Im very skeptical.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 88 5.7 Iroc, 2000 SS
Engine: Vortec Hot cam TPI/LS1
Transmission: Pro-Built/T-56
I've ran that cam on a L98 tuned port, it had great throttle response and really good mid-range, not a whole lot on top, but much better than say an LT1 cam. Not as much overall as the hotcam. but better mid range. Also that cam calls for a specific double spring. make sure to use whatever comp recommends or you WILL have problems, it has more aggressive lobes than oem.
Car: 1992 Camaro RS
I dont see anything indicating it's two separate castings. Their "Vortec" heads are "dual pattern" also so you can use standard intakes on their "Vortec" heads...
I know they're a reputable company and everything, but that whole thing just makes me really skeptical of what they're trying to accomplish. Are they Vortec ports or not on their Vortec heads? And why do they claim both intake types fit with no compromises? And does that have anything to do with their claim that their intake fits both types?
Sounds to me like it has dual bolt patterns, but the ports are standard.
Additionally, this manifold is the only one designed with bolt machining to fit all versions of Small Block Chevy cylinder heads, including classic originals, Vortec GM heads and late model perimeter corner vertical bolt style crate engine heads.
Engine: forged 350
Engine: forged 350
Car: 1992 Camaro RS
Engine: forged 350
O ok sorry I thought you were talking about the other intake yeah I don't know how that is I would think if it was made to fit the biggest ports the miss match when running the older heads would be horrible I don't think I'm going with this intake anymore but would like to see one in hand.
The car ran really well, was insanely fast in the mid-range, but had an oiling problem that was the fault of the builder and never ran to it's potential. When the oil pressure didn't bleed off it was a beast, it would get hot and run like crap because it wasn't oiling the bearings properly or keeping oil pressure.
my vortec/hotcam motor makes more- how much, don't know, but noticeably more. but it doesn't have the same assebly care the XR264 motor had (ported heads, matched valvetrain and degreed cam - it def made a difference) but is 03/04 M3 type of fast.
Just and FYI, I have a pro-built street/strip tranny. I stock transmission will not live for long even with a XR264,headers, & a tune.
Just a guess, the L98 was putting out about 300 flywheel HP, & the vortec/ hotcam is probably over 350 flywheel. An uncorked LS1 will still kill it on top-end, but not in the mid range.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Is he using RHS heads or stock L31 heads?
-- Joe
Engine: forged 350
I'm talking about the intake manifolds, not the heads, sorry for the confusion.
Honestly, I didn't give this much thought. I don't quite understand why people use vortec heads, so I just figured it's what he had and that wasn't negotiable. I've had a set of vortec heads in the garage for 10 years nobody wants. Only use AFR castings here...
-- Joe
-- Joe
he was just making the comments about the things RHS claim on there site about the intake I posted. Joined: Jul 1999
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm running AFR210s but I'm over 412 cubic inches.
-- Joe
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
