injectors for HSR
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
injectors for HSR
I was just about to order some Bosch 3's from Southbay and thought I'd better check on size. I have a stock L31 out of a 99 Tahoe and am about to install an HSR. For now no cam but probably next year something mild like a LT4 or similar (with spring upgrades...) Are 24lb injectors about right or ??
thanks
thanks
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: injectors for HSR
24s would do fine. With the Bosch you can raise the pressure with no ill effects to the injectors.
Car: 86 IROC
thanks guys, I'll get that order in. Southbay is great to deal with, the smaller Bosch injectors for the old 5.0 worked out great so they'll get my business again.
Car: 86 IROC
And while I'm asking dumb questions, I get that i have to use a small cap distributor. If i buy one from Rock Auto or Summit, for say a 1992 Z with the 5.7 (e.g. Cardone 841830), it would have the roller cam like the L31? so the gear drive (material) is the same?
Car: 1991 Z28 Vert
Correct, any V8 distributor aftr 1986 will work fine for you.
jerflash
Sep 24, 2015 03:11 PM
thejimsterz28
Sep 15, 2015 04:37 PM
