Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Fuel pressure question.
Old May 5, 2014 | 03:23 PM
riche's Avatar
Car: 1969 C-10 Truck
Engine: 355 Small Block, HSR, HP EFI ECM
Transmission: 700 R4
Axle/Gears: 373
I have a HSR and my FPR went out. Instead of waiting on a mail order on from Holley or an aftermarket one I just piced up a Buick one from the local autoparts store.
My question is I though that it would have a static fuel pressure of 43.5. Wrong, it is at 39psi... Should I let that bother me to bad?
My injectors are already too big IMO 36#.
I have a 355 with vortec heads. My cam only has .475 lift and a 108 lobe separation.
Thanks for any advice
Old May 5, 2014 | 06:36 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Fuel pressure question.
https://www.thirdgen.org/forums/tech...formation.html
it is at 39psi...
With or without the vac line connected ?
Old May 5, 2014 | 09:29 PM
riche's Avatar
Axle/Gears: 373
With it disconnected, it drops to 30 psi connected.
Old May 7, 2014 | 06:53 AM
riche's Avatar
Axle/Gears: 373
I used this calculator,
http://www.witchhunter.com/injectorcalc1.php
With a static pressure of 39 psi the injectors drop to 34 lb injectors. I don't believe that hurts me with my setup. Just looking for some reassurance that I am ok assuming that. B/c you know what they say when you assume...
Old May 19, 2014 | 08:46 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
With no vacuum you really want 43#. Lower than that and the fuel doesn't atomize as well. GM figured this out with the LS engines as they run much higher fuel pressure. AFPR aren't expensive and a good one will last many many years.
Old May 19, 2014 | 12:12 PM
riche's Avatar
Axle/Gears: 373
Thanks Tibo,
That was what I am worried about. We are only talking about 4.3 PSI but if that is enough to make the injectors not atomize correctly then I need to get a different regulator. I might go give Autozone hell and tell them to give me another FPR. Does anyone know if a Buick Grand National was suppose to have 43.5 PSI?
I should have just waited and ordered a Kirban...
Old May 19, 2014 | 01:42 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Just ask them to return it as defective because it doesn't put out a proper pressure. If the guy says no ask for a manager and if he says no ask for the district manager, all while being polite. Buy an aftermarket.
92camaroJoe
Jul 29, 2023 07:57 PM
Bryan F
Aug 18, 2015 02:28 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
