Upper radiator hose
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Upper radiator hose
Ok got a question what upper radiator hose is everyone using for the holley stealth ram intake since the tpi upper hose aint gonna work
Car: 1988 Camaro IROCZ
Engine: L31 350 HSR
Transmission: 700 R4
Axle/Gears: Borg Warner 3.27
Re: Upper radiator hose
From what Ive read get an upper hose for a Camaro RS of the same year. Some RS camaros came with a v6 and some with a v8. You want the upper hose for the V8 which was a regular tbi engine.
Engine: LR4 4.8
Ok so one from like a 1989 camaro tbi v8 car will work just fine thanks for the info
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
https://www.thirdgen.org/forums/alternative-port-efi-intakes/523914-tip-hsr-swap-upper.html
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
I used a 24" Gates flex coolant hose I ordered from Jegs. The tbi coolant hose didn't work for my setup for some reason.
Pac J
May 17, 2020 10:44 AM
