Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Better than tpi or stealthram??? Search for 5pp
Old Sep 13, 2016 | 12:52 AM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Axle/Gears: ls1 rear with 3.23
I have a built 383 tpi motor..love the torque..dislike the lack of hp..dynoed at 491tq 330 hp..
Tpis bigmouth and siamesed runners 190cc heads...crower 00903 cam (about 230 lift)
In my search for higher hp without loosing to much torque would a 58mm tb bring significant gains? Loose the tpi style intake altogether?
Any options besides stealth ram? Single plan style mpfi?
Anybody have any proven sbc combos with over 400 tq and hp?..no pwer addr
Old Sep 13, 2016 | 05:49 AM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: Better than tpi or stealthram??? Search for 5pp
Have you looked into Robb's setup? Dynamicefi.com? I have the p4 system keeps the'730 ECM but uses a daughter board instead of a chip tuning is then like HP tuners just flash the ECM...
Old Sep 13, 2016 | 08:31 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Stealth ram will gain good hp and lose good bit of peak trq but the stealth rams torque curve will be broader overall. Carry more after peak as rpm climb
58mm tb wont do anything on that setup as is
Old Sep 13, 2016 | 08:50 AM
gw082008's Avatar
Car: 92 Firebird Convertible
Engine: 383 - First Fuel Injection TPI
Axle/Gears: 3:23
You might consider FIRST FUEL INJECTION of Bristol, WI. It's a TPI system with huge runners. My 383 is very "happy" with it. I also use Dynamic EFI's P4 for engine managment.
Old Sep 13, 2016 | 08:55 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Any numbers or times for that setup?
Old Sep 14, 2016 | 07:41 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Accel Superram is a great street intake with good torque and there is also the FIRST TPI intake mentioned in previous post...
Dyno comparison on many intakes too bad FIRST wasnt tested..
http://s373.photobucket.com/user/gta...?sort=3&page=1
Old Sep 14, 2016 | 05:27 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
If you get a stealth ram and find yourself needing torque you can swap cam gears and stall for a proper setup (for shorter runners) and you will not be missing it anymore.
But My vote goes for the FIRST setup as well. No need to change many other parts and you can keep the torque.
Old Sep 14, 2016 | 08:51 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Where did that horsepower peak, what RPM? Do you have the dyno sheet handy?
Old Sep 15, 2016 | 12:12 AM
Crazy Canuck's Avatar
I've an '87 IROC 350 5sp.
What all is involved to go to a 383 stroker? Block is cracked.
Will TPI get me 400-430hp?
Or carb instead if straightforward eg no hood mod needed?
Lastly am in Vancouver Canada & wondering if a crate engine is best & who to buy from? US or Canada idc whatever is a better deal.
Thx
Old Sep 15, 2016 | 12:16 AM
Engine: LB9
Axle/Gears: 3.08
Thx
I have the perfect link for you.
CLICKME!
Old Sep 15, 2016 | 12:26 AM
CLICKME!
Thx but done already😂👍
Old Sep 15, 2016 | 12:32 AM
Engine: LB9
Axle/Gears: 3.08
No it's not done. You haven't started your own thread. Stop asking random questions in other threads and start your own using the link I gave you.
Old Sep 15, 2016 | 12:43 AM
Was done but forgot to submit
Thx
Old Sep 17, 2016 | 10:16 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
This thread seems to be painting a similar picture of what I remember about the FIRST TPI setup-- People posting actual dyno numbers or 1/4 mile times for them is as rare as a loche ness monster sighting. I was looking into a FIRST setup several years back but went single plane because of the lack of hard data on them (along with the price tag). Buy the Professional products efi single plane intake, an Accell throttle body and a carb throttle cable and you will cure your lower HP predicament. You will have less torque but your'e not towing something so how much can you really use down low anyway?
Old Sep 17, 2016 | 10:45 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The key to more HP is air flow, you need at least 330 cfm on each runner, to achieve that,
you need to do a lot of work.
A stealth ram ported will do it.
A FIRST out of the box will flow 300cfm on the base but the runners need help
(extrude hone).
See my sig. and read this:
https://www.thirdgen.org/forums/tpi/...owing-tpi.html
91z28ss
Apr 21, 2017 03:13 PM
-=Z28=-
Nov 7, 2016 10:59 AM
91dime
Sep 17, 2016 12:07 AM
Tibo
Sep 14, 2016 08:19 PM
firebrdo88
Sep 13, 2016 04:08 PM
